Home » Eclipse Projects » Eclipse Platform » Java editor annotations
Java editor annotations [message #116594] Tue, 26 August 2003 10:49 Go to next message
I have troubles with annotations in Java editor: there are a lot of
annotations saying: "the method XXX is undefined for the type YYY".
Everything is fine though, compilation works fine. Of course, no
correctins are available.
I noticed that some of these appeared when I wrote first the object
function call without having the method in the object code. I added the
method afterwards, but the annotation persisted. But it did happen for a
"normal" order: add a new method, then use the method.
Now my code is full of such fake annotations, I wasn't able to get rid of
them.
One more thing: such methods aren't seen by the content assistant as well.
They are displayed in the outline though.
Does anybody know a way to "refresh annotations"?
Emil
Re: Java editor annotations [message #116601 is a reply to message #116594] Tue, 26 August 2003 11:14 Go to previous messageGo to next message
Which build are you working on?
Darins
"Emil" <eiaco0@csr.uky.edu> wrote in message
news:bifs20$8ob$1@eclipse.org...
> them.
> Emil
Re: Java editor annotations [message #116607 is a reply to message #116601] Tue, 26 August 2003 11:17 Go to previous message
Version: 2.1.1
Build id: 200306271545
> Darins
> > them.
> > Thanks,
> > Emil
Previous Topic:A Requirements plugin...anybody interested?
Next Topic:Embeded external tools in Eclipse?
Current Time: Fri Nov 07 03:24:41 EST 2025
Powered by FUDForum. Page generated in 0.07158 seconds
