Home » Language IDEs » ServerTools (WTP) » Server Explorer problem
Server Explorer problem [message #116560] Wed, 06 July 2005 06:03 Go to next message
I have problem with server explorer. When I connect to MySQL 4.0.1.2
(Eclipse 3.1 WTP M5) Explorer works correct shows me db and list of the
tables but it couldn't shows me collumns, and when I try to see whole
content of the table I got an Exception
"Starting run
SELECT * FROM "price"."items"
java.sql.SQLException: Syntax error or access violation message from
server: "You have an error in your SQL syntax. Check the manual that
corresponds to your MySQL server version for the right syntax to use
near '"price"."items"' at line 1"
tell me if something wrong I do.
Re: Server Explorer problem [message #116588 is a reply to message #116560] Wed, 06 July 2005 08:54 Go to previous message
> "Starting run
I noticed this "bug" too yesterday. For now you need to write your own SQL
instead of using menu.
Instead of this construct (created by WTP) :
write your own SQL command to SQL Scrapbook page :
SELECT * FROM items
Frantisek Augusztin
Re: Server Explorer problem [message #116613 is a reply to message #116588] Wed, 06 July 2005 08:38 Go to previous message
>>"Starting run
> SELECT * FROM items
> Frantisek Augusztin
Thank you, Frantisek, But where can I found this "SQL Scrapbook page"?
Re: Server Explorer problem [message #116618 is a reply to message #116588] Wed, 06 July 2005 08:43 Go to previous message
>>"Starting run
> SELECT * FROM items
> Frantisek Augusztin
I'm sorry I found it thank you again.
But still as I undestand when I try to export/generate dtd - it shows
tables without fields
Re: Server Explorer problem [message #116623 is a reply to message #116613] Wed, 06 July 2005 08:52 Go to previous message
>>>"Starting run
>> SQL instead of using menu.
>> SELECT * FROM items
>> Frantisek Augusztin
Ctrl+N : Data->SQL Scrabook Page
Previous Topic:adding user library to tomcat classpath
Next Topic:Porting WST-XSD-Editor to Swing
Current Time: Sat Jul 26 09:11:50 EDT 2025
Powered by FUDForum. Page generated in 0.06460 seconds
