Home » Language IDEs » C / C++ IDE (CDT) » Code assist and C++ Template classes
Code assist and C++ Template classes [message #116437] Fri, 20 August 2004 09:19 Go to next message
Originally posted by: atingley.sonusnet.com
It appears CDT code assist doesn't understand C++ Template classes.
Anytime I try ctl-space on a class that is a template class, I get
"no completions available." Is this a feature yet to be implemented?
Al
Re: Code assist and C++ Template classes [message #116452 is a reply to message #116437] Fri, 20 August 2004 12:31 Go to previous message
The parser does try to understand C++ templates, though there are cases
that it does not handle correctly. This is an area that is still under
development. Content assist feature should work as long as the parser didn't
have trouble with your template.
Check out the following defects in bugzilla (http://bugs.eclipse.org) to see
some of the code patterns that the parser currently has problems with:
60307, 65419, 71884, 51485, 39701.
-Andrew
"Alan Tingley" <atingley@sonusnet.com> wrote in message
news:cg4toa$lf$1@eclipse.org...
> Al
Previous Topic:Setting break point on code in header file
Next Topic:_WinMain@16
Current Time: Fri Nov 07 06:57:25 EST 2025
Powered by FUDForum. Page generated in 0.03805 seconds
