Home » Modeling » GMF (Graphical Modeling Framework) » Compartment default decoration
Compartment default decoration [message #116397] Tue, 03 April 2007 06:26 Go to next message
Originally posted by: angelo.marguglio.eng.it
Hi all! I'd like to hide the defalt compartment decoration that is the
little triagle on the left side of its figure. I manage compartment
visibility programmatically, so I don't want to see this decoration (I
suppose that it's a decoration). How can I reach this aim?
Thanks in advance!
AM
Re: Compartment default decoration [message #116453 is a reply to message #116397] Tue, 03 April 2007 08:29 Go to previous messageGo to next message
Originally posted by: fbanica.soluta.net
In the graphical definition (.gmfgraph) there's a property of the
compartment which says if is collapsible or not (see attachment)...
"Angelo Marguglio" <angelo.marguglio@eng.it> wrote in message
news:euta5l$6bu$1@build.eclipse.org...
> Thanks in advance!
> AM
Re: Compartment default decoration [message #117135 is a reply to message #116453] Wed, 04 April 2007 11:51 Go to previous messageGo to next message
Hi Florin! Thanks for your answer, but I already use this setting, but the
triangle is still visible. Have you got any idea for this behaviour?
Thanks! AM
"Florin Banica" <fbanica@soluta.net> ha scritto nel messaggio
news:euthc0$cpd$1@build.eclipse.org...
>> Thanks in advance!
>> AM
Re: Compartment default decoration [message #117197 is a reply to message #117135] Wed, 04 April 2007 12:31 Go to previous messageGo to next message
I'm confused, the triangle is still there? And the compartment is
collapsible? Did you set the "Collapsible" property to false?
Did I get it right or I'm missing somthing?
Ciao e buon lavoro!
news:ev0hhn$sak$1@build.eclipse.org...
> Thanks! AM
>>> Thanks in advance!
>>> AM
Re: Compartment default decoration [message #117416 is a reply to message #116397] Thu, 05 April 2007 10:12 Go to previous messageGo to next message
Angelo,
If you want to change the appearance of the little triangle, it is
created in the method
ResizableCompartmentEditPolicy.createCollapseHandles().
Cherie
> Thanks in advance!
> AM
Re: Compartment default decoration [message #119568 is a reply to message #117197] Mon, 16 April 2007 08:32 Go to previous messageGo to next message
Thanks a lot for your help! You understood weel, but it isn't important now:
I've solved thanks to Cherie's tip!
BYE
AM
news:ev0k04$57c$1@build.eclipse.org...
> Ciao e buon lavoro!
>> the triangle is still visible. Have you got any idea for this behaviour?
>> Thanks! AM
>>>> Thanks in advance!
>>>> AM
*** SOLVED *** - Re: Compartment default decoration [message #119580 is a reply to message #117416] Mon, 16 April 2007 08:33 Go to previous message
Thanks a lot for your tip!!!! It works fine for me!
BYE
AM
"Cherie Revells" <crevells@ca.ibm.com> ha scritto nel messaggio
news:ev304g$bv7$2@build.eclipse.org...
> Angelo,
> If you want to change the appearance of the little triangle, it is created
> in the method ResizableCompartmentEditPolicy.createCollapseHandles().
> Cherie
>> Thanks in advance!
>> AM
Previous Topic:Corrupting Diagram file
Next Topic:Regarding tabbed properties view
Current Time: Mon Sep 22 15:32:31 EDT 2025
Powered by FUDForum. Page generated in 0.06408 seconds
