Errors after Tomcat reload [message #116394] |
Fri, 22 August 2008 11:55  |
I have a problem with our struts based web application that we deploy on
tomcat with bridgeservlet and equinox.
The application works fine after it is deployed. But as soon as we
reload the context, the following exception is thrown for any requests:
org.apache.jasper.JasperException: Unable to initialize
TldLocationsCache: No bundle found for URL:
bundleentry://1/web/lib/antlr.jar
org.apache.jasper.compiler.TldLocationsCache.init(TldLocatio nsCache.java:253)
org.apache.jasper.compiler.TldLocationsCache.getLocation(Tld LocationsCache.java:224)
org.apache.jasper.JspCompilationContext.getTldLocation(JspCo mpilationContext.java:526)
org.apache.jasper.compiler.Parser.parseTaglibDirective(Parse r.java:422)
After debugging I found the follwing:
- The root of the exception is an IOException thrown in
BundleResourceHandler:openConnection(URL) because the static
BundleContext in BundleResourceHandler is not valid and therefore the
bundle referenced in the URL cannot be found.
- apparently some objects of the "old" framework - ie the framework that
was used before the reload - are still around
- A possible cause for this is in
sun.net.www.protocol.jar.JarFileFactory: JarFileFactory caches instances
of JarFiles and maps JarFiles to URLs. If the JarFileFactory survives a
reload operation it will return "old" URLs that still reference
BundleResourceHandlers with invalid values.
I'm very greatful for any hints and pointers.
Peter
Re: Errors after Tomcat reload [message #116500 is a reply to message #116485] |
Mon, 25 August 2008 11:29   |
Simon, thanks a lot! Building a new version of the bridge servlet
helped. Also thanks for the other suggestions.
Peter
Simon Kaegi schrieb:
> Hi Peter,
> Thanks, that helps. When I get the chance I'll try that out, but for now....
> a few things I noticed.
> One thing I can see that you will want to fix is the inclusion of the
> javax.servlet bundle.
> When running under the servletbridge the servlet api comes from the app
> server so it's important not have this bundle as it can lead to all sorts of
> class loading mixups. On the other hand you do need javax.servlet.jsp as the
> servletbridge isolates you from the many not so fun idiosyncrasies of the
> JSP engines providided buy the app server vendors.
> You definitely should also build your own bridge.war. The bridge.war that is
> up on the website is not a formal distribution and was just put up as a
> quickstart mechanism. You should download the
> org.eclipse.equinox.servletbridge project and run the war builder ant script
> to build your own.
> HTH
> -Simon
> "Peter Kullmann" <p.kullmann@arenae.ch> wrote in message
> news:g8ohia$34d$1@build.eclipse.org...
>> Dear Simon
>> Luckily this problem can be reproduced quite easily: It happens with the
>> struts example application also. Here is what I did:
>> - Deploy bridge.war (from equinox website)
>> - Copy the following bundles to bridge/WEB-INF/eclipse/plugins
>> - org.eclipse.equinox.struts.examples (downloaded from sf.net, imported
>> into a workspace and built)
>> - javax.servlet 2.4.0
>> - javax.servlet.jsp (both from orbit)
>> - org.apache.jasper
>> - org.apache.commons.logging
>> - org.apache.commons.el
>> - org.apache.ant
>> - org.eclipse.equinox.jsp.jasper (all 5 from an eclipse 3.4.0 install)
>> - org.eclipse.equinox.http.helper (from CVS)
>> - org.eclipse.equinox.jsp.jstl (from sf.net)
>> With this setup I need to start the struts examples bundle manually in the
>> console, then I hit
>> http://localhost:8080/bridge/struts-examples/welcome.do which works fine.
>> After a reload of the bridge context, the same URL does no longer work but
>> instead throws the exception below.
>> To answer your questions:
>> - pure OSGi, I'm not sure but I think so
>> - orgi.parentClassLoader and the other one are both set to "ext".
>> Thanks
>> Peter
>>> Bizarre. Holding on to URLs in stopped frameworks is definitely going to
>>> cause problems. From what I can see someone is holding on to one of these
>>> old URLs. When the context is reloaded the OSGi framework is re-rooted
>>> with a whole new class loader so that would lead me to believe the URL is
>>> being cached outside of the OSGi framework.
>>> A few questions...
>>> Is your webapp a pure OSGi based application or is it somehow a mixed
>>> content hybrid?
>>> Is your servletbridge really isolated from the servlet container? e.g.
>>> what is your settings for:
>>> osgi.parentClassloader and osgi.contextClassLoaderParent in your
>>> launch.ini?
>>> Any additional info about your config would help.
>>> -Simon
>>> news:g8mnhn$lib$1@build.eclipse.org...
>>>> Peter
Re: Errors after Tomcat reload [message #117003 is a reply to message #116992] |
Tue, 02 September 2008 22:51  |
Nevermind... I found your bug report.
Thanks.
"Simon Kaegi" <simon_kaegi@ca.ibm.com> wrote in message
news:g9kspq$7ie$1@build.eclipse.org...
> Yes, please log a bug against Orbit and if you wouldn't mind CC me on the
> bug and I'll follow up.
> AFAIK no-one should be using require-bundle in any of Orbit'd bundles.
> -Simon
> news:g9g8m5$t0i$1@build.eclipse.org...
>> <snip/>
>>> sorts of class loading mixups. On the other hand you do need
>>> javax.servlet.jsp as the servletbridge isolates you from the many not so
>>> fun idiosyncrasies of the JSP engines providided buy the app server
>>> vendors.
>> Hi Simon
>> I tried to remove the javax.servlet bundle but unfortunately
>> javax.xml.rpc from orbit has a dependency in the require-bundle section
>> for javax.servlet and therefore some of my bundles won't resolve. What
>> can I do in this situation? Create my own version of javax.xml.rpc? (and
>> ask orbit to use import package instead of require bundle)?
>> Thanks
>> Peter
FUDForum. Page generated in 0.04631 seconds
