Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » HibernateConfiguration not accessable
HibernateConfiguration not accessable [message #116317] Fri, 28 March 2008 10:58 Go to next message
Hi Martin,
I like to manipulate the Hibernate configuration programmatically. I want
to install an own event listener.
Now I've found that the HbDataStore.getHibernateConfiguration() is
protected. Since I get the HbDataStore from the HbHelper and by this way
from a factory I don't know (and don't want to know) the implementation
class. Is there a reason for making the getHibernateConfiguration() method
protected?
Or is there another way to configure my listener? Since the listener
implements three interfaces a hibernate xml configuration file does not
work.
Manfred
Ps. Sorry for having so many questions today!
Re: HibernateConfiguration not accessable [message #116322 is a reply to message #116317] Fri, 28 March 2008 11:39 Go to previous messageGo to next message
Hi Manfred,
Many questions are no problem, they help to improve the solution.
Currently the best way to add your own listeners is to override the HbSessionDataStore and then
override the createConfiguration method (calls super and change the configuration before returning
it). You also need to register your own datastore factory using HbHelper.setHbDataStoreFactory.
I can imagine that there could be an easier solution so that you don't need to override the hbdatastore.
If you are interested in this, can you enter a bugzilla, then I can make this easier so that it is
not required to specify your hbdatastore implementation?
gr. Martin
Manfred Hahn wrote:
> Hi Martin,
> want to install an own event listener.
> method protected?
> work.
> Regards
> Manfred
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: HibernateConfiguration not accessable [message #116326 is a reply to message #116322] Fri, 28 March 2008 12:04 Go to previous message
Hi Martin,
I will follow your advice.
The simple approach to cast the HbDataStore to HbSessionDataStore and
getting the Configuration did not work, because the Configuration I've got
before initialization of the DataStore was null, and after the
initialization the setting of the EventListeners seem to have no effect.
My Lister was not called.
Best Regards
Manfred
Re: HibernateConfiguration not accessable [message #616027 is a reply to message #116317] Fri, 28 March 2008 11:39 Go to previous message
Hi Manfred,
gr. Martin
Manfred Hahn wrote:
> Hi Martin,
> method protected?
> work.
> Regards
> Manfred
The Netherlands
Re: HibernateConfiguration not accessable [message #616028 is a reply to message #116322] Fri, 28 March 2008 12:04 Go to previous message
Hi Martin,
Best Regards
Manfred
Previous Topic:HibernateConfiguration not accessable
Next Topic:[CDO] Transactional Editing Domain
Current Time: Mon Jun 23 22:39:09 EDT 2025
Powered by FUDForum. Page generated in 0.03629 seconds
