Problem with diagram creation from model file [message #116188] |
Mon, 02 April 2007 09:23  |
Originally posted by: christian.daenekas.informatik.uni-oldenburg.de
I think I discovered a potential problem with the creation of diagrams
from model files. I use this function in my RCP diagram editor and it
seemed to work pretty good. But yesterday I discovered a wrong diagram
being created from a valid model file. I have 5 EMF classes.
Specializations of these classes (distinguished by different attribute
initializations) are represented as nodes that can directly be created
by the tools from the palette. Some of these "TopLevel" nodes have
compartments, some not. Also the child references that are associated
with a compartment are different from node to node (even if it
references the same EMF class). Now the problem:
I´ve got a model file with one root node. This node has multiple
childnodes. Some of these childnodes do have childnodes themselfes and
so on. I´ve noticed that there are sometimes wrong nodes selected to
represent an element in the semantic model. This leads to the situation
that an element with child elements is represented by a node without a
compartement and the child elements are not displayed and cannot be
altered. Still the elements stay in the semantic model. This situation
seems to depend on the depth in the treestructure the element is placed
in. Are the nodes that represent a certain EMF class randomly chosen
during diagram creation (if there is more than one possibility for a
class)? This situation severly impacts the functionality of my
application, so any advice on this is more than welcome. Thanks in advance.
Greetings,
Christian
Re: Problem with diagram creation from model file [message #116352 is a reply to message #116344] |
Mon, 02 April 2007 11:21   |
Okay,
I tried this, but it seems that the constraints are not evaluated. The
behaviour of the creation process doesn´t change and the Method matches
that should do the evaluation is not called. Since the action for
diagram creation isn´t included in the RCP version of an editor I
created a class myself that is responsible for diagram creation. Do I
have to call the constraint evaluation explicitly or is this an internal
thing. Maybe you could take a look on the code to tell me if I forgot
something:
package de.permeter.analysis.editor.metric.diagram.part;
import java.io.IOException;
import java.util.Collections;
import org.eclipse.core.commands.ExecutionException;
import org.eclipse.core.commands.operations.OperationHistoryFactory ;
import org.eclipse.core.runtime.IAdaptable;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.core.runtime.NullProgressMonitor;
import org.eclipse.emf.common.ui.URIEditorInput;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.common.util.WrappedException;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.transaction.TransactionalEditingDomain;
import org.eclipse.gmf.runtime.common.core.command.CommandResult;
import org.eclipse.gmf.runtime.diagram.core.services.ViewService;
import
org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTr ansactionalCommand;
import org.eclipse.gmf.runtime.emf.core.GMFEditingDomainFactory;
import org.eclipse.gmf.runtime.notation.Diagram;
import org.eclipse.jface.dialogs.MessageDialog;
import org.eclipse.jface.viewers.IStructuredSelection;
import org.eclipse.ui.IWorkbench;
import org.eclipse.ui.IWorkbenchPart;
import org.eclipse.ui.PartInitException;
import org.eclipse.ui.WorkbenchException;
import de.permeter.analysis.editor.metric.DocumentRoot;
import de.permeter.analysis.editor.metric.diagram.edit.parts.Metric EditPart;
public class MetricEditOperation
IStructuredSelection mySelection;
String metricId;
String metricPath;
IWorkbench workbench;
IWorkbenchPart myPart;
public MetricEditOperation(IStructuredSelection mySelection, String
metricId, String metricPath,
IWorkbench workbench, IWorkbenchPart myPart)
super();
this.mySelection = mySelection;
this.metricId = metricId;
this.metricPath = metricPath;
this.workbench = workbench;
this.myPart = myPart;
public void execute() {
// Creation of URIEditorInput that is used to create diagram resource
URI modelUri = URI.createFileURI(metricPath);
URIEditorInput input = new URIEditorInput(modelUri);
// Root Object of the semantic model is resolved
TransactionalEditingDomain editingDomain =
GMFEditingDomainFactory.INSTANCE.createEditingDomain();
ResourceSet resourceSet = editingDomain.getResourceSet();
EObject diagramRoot = null;
try
Resource resource = resourceSet.getResource(input.getURI(), true);
diagramRoot = (EObject) resource.getContents().get(0);
catch (WrappedException ex)
MetricDiagramEditorPlugin.getInstance().logError(
"Unable to load resource: " + input.getURI().toFileString(), ex);
//$NON-NLS-1$
if (diagramRoot == null)
MessageDialog.openError(myPart.getSite().getShell(), "Error", "Model
file loading failed");
return;
// Hidden root object of type DocumentRoot is replaced by actual root
object metric for diagram creation
DocumentRoot docRoot = (DocumentRoot) diagramRoot;
final EObject myDiagramRoot = docRoot.getMetric();
//System.out.println("Root: " + myDiagramRoot.toString());
// Diagram will be stored in the same place as semantic model by the
same name (extension .metric is replaced by .metric_diagram)
String originalFileName = metricPath.subSequence(0,
metricPath.length() - 7).toString();
String fileExtension = ".metric_diagram"; //$NON-NLS-1$
String fileName = originalFileName + fileExtension;
//System.out.println("Zu erstellende Datei: " + fileName);
// Input for diagram editor is created
URI diagramFileUri = URI.createFileURI(fileName);
URIEditorInput diagramFile = new URIEditorInput(diagramFileUri);
//System.out.println("Diagram da?: " + diagramFile.exists());
final Resource diagramResource =
resourceSet.createResource(diagramFile.getURI());
// If there is already an diagram file it is opened, otherwise it gets
created.
if (diagramFile.exists())
try
workbench.showPerspective(" de.permeter.analysis.editor.metric.diagram.MetricPerspective ",
workbench
.getActiveWorkbenchWindow());
MetricDiagramEditorUtil.openDiagram(diagramResource);
catch (PartInitException e1)
// TODO Auto-generated catch block
e1.printStackTrace();
catch (WorkbenchException ex)
ex.printStackTrace();
else
// creation of diagram contents
AbstractTransactionalCommand command = new
AbstractTransactionalCommand(editingDomain,
"Initializing diagram contents", null) { //$NON-NLS-1$
protected CommandResult doExecuteWithResult(IProgressMonitor
monitor, IAdaptable info)
throws ExecutionException
int diagramVID =
MetricVisualIDRegistry.getDiagramVisualID(myDiagramRoot);
if (diagramVID != MetricEditPart.VISUAL_ID)
return CommandResult.newErrorCommandResult("Incorrect model object
stored as a root resource object"); //$NON-NLS-1$
Diagram diagram = ViewService.createDiagram(myDiagramRoot,
MetricEditPart.MODEL_ID,
MetricDiagramEditorPlugin.DIAGRAM_PREFERENCES_HINT);
diagramResource.getContents().add(diagram);
return CommandResult.newOKCommandResult();
// diagram is saved to file, perspective gets switched to editor and
diagram gets opened.
try
OperationHistoryFactory.getOperationHistory().execute(comman d, new
NullProgressMonitor(), null);
diagramResource.save(Collections.EMPTY_MAP);
try
workbench
catch (ExecutionException ex)
MetricDiagramEditorPlugin.getInstance().logError("Unable to create
model and diagram", ex); //$NON-NLS-1$
catch (IOException ex)
"Save operation failed for: " + diagramFileUri.toFileString(),
ex); //$NON-NLS-1$
catch (PartInitException ex)
MetricDiagramEditorPlugin.getInstance().logError("Unable to open
editor", ex); //$NON-NLS-1$
Alex Shatalin schrieb:
> Hello Christian,
> Yes, you are right. OCL constraint should looks like: self.class = 'test'
> Alex Shatalin
Re: Problem with diagram creation from model file [message #116368 is a reply to message #116360] |
Mon, 02 April 2007 14:33  |
Hello Christian,
> Ok, could you explain your suggestion any further? "non-synchronized"
> is an option I can find in a model (gmfgen?)? And afterwards I
Yes there is a boolean property for GenDiagram - "synchronized". You can
set it to "false" and regenrate the code.
> generate a NON-RCP version of the diagram plugin? Would be nice if you
> could let me know if I got everything right you suggested.
That's right. I'm suggesting to generate non-RCP version of non-synchronized
diagram for your mapping, take generated "InitDiagramFileAction" and patch
it to make it applicable for RCP version..
Alex Shatalin
FUDForum. Page generated in 0.24996 seconds
