Home » Archived » Test and Performance Tools Platform (TPTP) » How to find the results(pass/fail) after running test cases
How to find the results(pass/fail) after running test cases [message #116138] Mon, 22 October 2007 09:06 Go to next message
I create a test suite with simple test cases using AGR. After running the
test suite i want to know how many test suites are passed/failed.
For example in my application i has validate the user entry in the text
field and displayed error message in the dialog if the value is not valid.
For this i can able to record this scenario using AGR but after running
this test suite i want to diaplay the result(pass/fail).
Thanks for your help.
Pushparaj
Re: How to find the results(pass/fail) after running test cases [message #117267 is a reply to message #116138] Tue, 06 November 2007 07:42 Go to previous message
Hi Pushparaj,
After running the AGR test suite, an execution history or test log file
is created. You can open it in the Test Log viewer which contains an
overview and the details:
http://help.eclipse.org/help33/topic/org.eclipse.hyades.test .doc.user/ref/r_testlog_overview.html
Paul
"Pushparaj" <pushparaj_94@yahoo.com> wrote in message
news:593e6a8b16cb80ac45d36e71d1b408e7$1@www.eclipse.org...
> Pushparaj
Previous Topic:[AGR] Hang problem in AGR 4.4
Next Topic:AGR hangs while playing a recorded simple dialog spawned from ProgressMonitorDia
Current Time: Tue Jul 22 09:43:52 EDT 2025
Powered by FUDForum. Page generated in 0.05260 seconds
