Home » Language IDEs » Java Development Tools (JDT) » HTTPUnit vs. Eclipse - VerifyError
HTTPUnit vs. Eclipse - VerifyError [message #115949] Tue, 11 November 2003 19:10 Go to next message
Originally posted by: coop.us.ibm.com
All,
I'm trying to run JUnit tests containing HTTPUnit calls as a JUnit
test. When I do so, I'm getting the following error:
java.lang.VerifyError: (class:
com/meterware/httpunit/parsing/NekoHTMLParser, method: parse signature:
(Ljava/net/URL;Ljava/lang/String;Lcom/meterware/httpunit/par sing/DocumentAdapter;)V)
Incompatible object argument for method call
at java.lang.Class.forName1(Native Method)
at java.lang.Class.forName(Class.java:142)
com.meterware.httpunit.parsing.HTMLParserFactory.loadParserI fSupported(HTMLParserFactory.java:183)
com.meterware.httpunit.parsing.HTMLParserFactory.<clinit>(HTMLParserFactory.java:194)
at com.meterware.httpunit.HTMLPage.parse(HTMLPage.java:244)
at com.meterware.httpunit.WebResponse.getReceivedPage(WebRespon se.java:975)
at com.meterware.httpunit.WebResponse$Scriptable.load(WebRespon se.java:577)
com.meterware.httpunit.javascript.JavaScript$Window.initiali ze(JavaScript.java:419)
at com.meterware.httpunit.javascript.JavaScript.run(JavaScript. java:80)
com.meterware.httpunit.javascript.JavaScriptEngineFactory.as sociate(JavaScriptEngineFactory.java:46)
at com.meterware.httpunit.FrameHolder.<init>(FrameHolder.java:44)
at com.meterware.httpunit.WebWindow.<init>(WebWindow.java:218)
at com.meterware.httpunit.WebClient.<init>(WebClient.java:51)
at com.meterware.httpunit.WebConversation.<init>(WebConversation.java:46)
at w3.httpunit.HomepageHttpTest.setUp(HomepageHttpTest.java:44)
at junit.framework.TestCase.runBare(TestCase.java:125)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:395)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:279)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:171)
Any clue what I'm doing wrong? I assume it's a classpath error, but
can't for the life of me figure out what's messed up with the classpath.
Btw, this HTTPUnit test works fine from the commandline.
Thanks!
/Coop
Re: HTTPUnit vs. Eclipse - VerifyError [message #116041 is a reply to message #115949] Wed, 12 November 2003 07:14 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
I got similar exceptions when there was 2 or more version of a library (in
your case httpunit) on the run/debug classpath and the first one was not the
one I wrote code against. You should check the classpath of the test run
(Classpath tab in the appropriate Run configuration) and check whether there
are more httpunit.jar (or similar) exists. If this is the case simply move
the one you use above for the others.
HTH,
Csaba
"Stephen Cooper" <coop@us.ibm.com> wrote in message
news:bortmt$olc$1@eclipse.org...
> All,
pter;)V)
> at
> at
java:194)
> at
> at
> at
va:419)
> at
> at
nner.java:395)
> at
java:279)
> at
..java:171)
> Thanks!
> /Coop
Re: HTTPUnit vs. Eclipse - VerifyError [message #116050 is a reply to message #115949] Wed, 12 November 2003 09:11 Go to previous message
Originally posted by: olivier_thomann.ca.ibm.comNOSPAM
Le Tue, 11 Nov 2003 17:10:39 -0700, Stephen Cooper <coop@us.ibm.com> a
écrit :
What VM are you using? Could it be due to incompatible versions of
xerces on the classpath?
Olivier
Previous Topic:Scrapbook - Internal error
Next Topic:eclipse 2.1.2 errors on mac os x 10.2.6
Current Time: Mon Oct 27 11:27:08 EDT 2025
Powered by FUDForum. Page generated in 0.24614 seconds
