Home » Archived » Visual Editor (VE) » ve creates widgets by itself
ve creates widgets by itself [message #115947] Thu, 26 January 2006 11:00 Go to next message
Originally posted by: alexandre.gzsistemas.com.br
Hi again,
There is something so strange happening. I saw that when I move some
widgets over a Shell, ve creates new objects fom the same widget that is
being moved.
Why it happens ?
Thanks.
Re: ve creates widgets by itself [message #116447 is a reply to message #115947] Tue, 31 January 2006 12:59 Go to previous messageGo to next message
--------------000303000806090100010600
Alexandre Boaventura escreveu:
> Hi again,
> being moved.
> Why it happens ?
> Thanks.
I'll try this post again because three other programmers here in the
company began to use Visual Editor on a new project and the error occurs
with them too.
What we noticed is that this error only happens with GridLayout. With
other layouts , it's ok.
And when we remove this "self-created widgets" from within the Visual
Editor, it causes error on the program (e.g., label44 cannot be resolved).
Attached is the error log.
Thank you.
name="_error.log.log"
Content-Disposition: inline;
filename="_error.log.log"
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:33:19.171
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:33:19.171
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.NullPointerException
at org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:790)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:822)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicIsSet(Ba sicEObjectImpl.java:609)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:600)
at org.eclipse.ve.internal.java.core.BeanPropertySourceAdapter. getPropertyValue(BeanPropertySourceAdapter.java:90)
at org.eclipse.ve.internal.swt.WidgetPropertySourceAdapter.getP ropertyValue(WidgetPropertySourceAdapter.java:365)
at org.eclipse.ve.internal.propertysheet.command.CommandStackPr opertySheetEntry.primGetValues(CommandStackPropertySheetEntr y.java:173)
at org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshValues(AbstractPropertySheetEntry.java:892)
at org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshChildEntries(AbstractPropertySheetEntry.java:823 )
at org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry$3.run(AbstractPropertySheetEntry.java:879)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 18 more
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:35:11.93
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:35:11.93
!STACK 0
at org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValues(AbstractPropertySheetEntry.java:1028)
at org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertySheetViewer.java:875)
at org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged(PropertySheetPage.java:392)
at org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.superSelectionChanged(EToolsPropertySheetPage.java:250)
at org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.access$2(EToolsPropertySheetPage.java:243)
at org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e$1.run(EToolsPropertySheetPage.java:236)
... 18 more
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:35:21.640
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:35:21.640
!STACK 0
... 18 more
!ENTRY org.eclipse.ve.java.core 4 0 2006-01-31 15:37:36.171
!MESSAGE Exception thrown.
!STACK 0
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:951)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2272)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:889)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany (XMLSaveImpl.java:2001)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1221)
at org.eclipse.emf.ecore.xmi.impl.XMISaveImpl.writeTopObjects(X MISaveImpl.java:78)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:478)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:206)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:193)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:893)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:813)
at org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doSaveCache(VEModelCacheUtility.java:158)
at org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.doSave(JavaSourceTranslator.java:1358)
at org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or$2.doRun(JavaSourceTranslator.java:923)
at org.eclipse.ve.internal.java.codegen.util.ReverseParserJob.r un(ReverseParserJob.java:56)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!ENTRY org.eclipse.ve.java.core 4 0 2006-01-31 15:37:37.187
!STACK 0
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.doSave(JavaVisualEditorPart.java:2817)
at org.eclipse.ui.internal.SaveableHelper$1.run(SaveableHelper. java:95)
at org.eclipse.ui.internal.SaveableHelper$2.run(SaveableHelper. java:116)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:624)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:621)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2134)
at org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOpe ration(SaveableHelper.java:122)
at org.eclipse.ui.internal.SaveableHelper.savePart(SaveableHelp er.java:100)
at org.eclipse.ui.internal.EditorManager.savePart(EditorManager .java:1154)
at org.eclipse.ui.internal.WorkbenchPage.savePart(WorkbenchPage .java:2714)
at org.eclipse.ui.internal.WorkbenchPage.saveEditor(WorkbenchPa ge.java:2727)
at org.eclipse.ui.internal.SaveAction.run(SaveAction.java:69)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at org.eclipse.jface.commands.ActionHandler.execute(ActionHandl er.java:117)
at org.eclipse.core.commands.Command.execute(Command.java:311)
at org.eclipse.core.commands.ParameterizedCommand.execute(Param eterizedCommand.java:396)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(WorkbenchKeyboard.java:459)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Workben chKeyboard.java:781)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(WorkbenchKeyboard.java:828)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings(WorkbenchKeyboard.java:550)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(Work benchKeyboard.java:493)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter .handleEvent(WorkbenchKeyboard.java:117)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:917 )
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:852)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:880)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:876)
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1190)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:3135)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3038 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3706 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:16 56)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2711)
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:50:37.484
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:50:37.484
!STACK 0
... 18 more
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:51:15.859
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:51:15.859
!MESSAGE 2
!STACK 0
java.lang.ArrayIndexOutOfBoundsException: 2
at org.eclipse.ve.internal.swt.GridLayoutGridFigure.calculateRo wDividers(GridLayoutGridFigure.java:295)
at org.eclipse.ve.internal.swt.GridLayoutGridFigure.<init>(GridLayoutGridFigure.java:60)
at org.eclipse.ve.internal.swt.GridLayoutEditPolicy.getGridLayo utGridFigure(GridLayoutEditPolicy.java:315)
at org.eclipse.ve.internal.swt.GridLayoutEditPolicy.showGridFig ure(GridLayoutEditPolicy.java:356)
at org.eclipse.ve.internal.swt.GridLayoutEditPolicy.gridVisibil ityChanged(GridLayoutEditPolicy.java:421)
at org.eclipse.ve.internal.cde.core.GridController.setGridShowi ng(GridController.java:212)
at org.eclipse.ve.internal.swt.GridLayoutEditPolicy$3.selectedS tateChanged(GridLayoutEditPolicy.java:525)
at org.eclipse.gef.editparts.AbstractEditPart.fireSelectionChan ged(AbstractEditPart.java:407)
at org.eclipse.gef.editparts.AbstractEditPart.setSelected(Abstr actEditPart.java:952)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.appendSelect ion(AbstractEditPartViewer.java:171)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.select(Abstr actEditPartViewer.java:564)
at org.eclipse.gef.tools.CreationTool.selectAddedObject(Creatio nTool.java:269)
at org.eclipse.gef.tools.CreationTool.performCreation(CreationT ool.java:255)
at org.eclipse.gef.tools.CreationTool.handleButtonUp(CreationTo ol.java:178)
at org.eclipse.gef.tools.AbstractTool.mouseUp(AbstractTool.java :1053)
at org.eclipse.gef.EditDomain.mouseUp(EditDomain.java:259)
at org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Released(DomainEventDispatcher.java:374)
at org.eclipse.draw2d.LightweightSystem$EventHandler.mouseUp(Li ghtweightSystem.java:547)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:137)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:51:15.875
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:51:15.875
!MESSAGE 2
!STACK 0
at org.eclipse.ve.internal.swt.GridLayoutEditPolicy.createGridL ayoutRequest(GridLayoutEditPolicy.java:687)
at org.eclipse.ve.internal.swt.GridLayoutEditPolicy.showLayoutT argetFeedback(GridLayoutEditPolicy.java:475)
at org.eclipse.gef.editpolicies.LayoutEditPolicy.showTargetFeed back(LayoutEditPolicy.java:345)
at org.eclipse.gef.editparts.AbstractEditPart.showTargetFeedbac k(AbstractEditPart.java:1002)
at org.eclipse.gef.tools.TargetingTool.showTargetFeedback(Targe tingTool.java:334)
at org.eclipse.ve.internal.cde.core.CDECreationTool.showTargetF eedback(CDECreationTool.java:131)
at org.eclipse.gef.tools.TargetingTool.handleEnteredEditPart(Ta rgetingTool.java:191)
at org.eclipse.gef.tools.TargetingTool.setTargetEditPart(Target ingTool.java:316)
at org.eclipse.gef.tools.TargetingTool.updateTargetUnderMouse(T argetingTool.java:383)
at org.eclipse.gef.tools.CreationTool.handleMove(CreationTool.j ava:238)
at org.eclipse.gef.tools.AbstractTool.mouseMove(AbstractTool.ja va:1038)
at org.eclipse.gef.EditDomain.mouseMove(EditDomain.java:248)
at org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Moved(DomainEventDispatcher.java:359)
at org.eclipse.draw2d.LightweightSystem$EventHandler.mouseMove( LightweightSystem.java:542)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:145)
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:51:15.890
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:51:15.890
!MESSAGE 2
!STACK 0
at org.eclipse.gef.tools.CreationTool.handleMove(CreationTool.j ava:240)
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:51:15.906
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:51:15.906
!MESSAGE 2
!STACK 0
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:51:16.15
!MESSAGE 2
!STACK 0
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:51:16.156
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:51:16.156
!MESSAGE Failed to execute runnable (java.lang.IllegalArgumentException: Figure is not a child)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.IllegalArgumentException: Figure is not a child)
Caused by: java.lang.IllegalArgumentException: Figure is not a child
at org.eclipse.draw2d.Figure.remove(Figure.java:1173)
at org.eclipse.draw2d.FreeformLayer.remove(FreeformLayer.java:7 8)
at org.eclipse.gef.editpolicies.GraphicalEditPolicy.removeFeedb ack(GraphicalEditPolicy.java:73)
at org.eclipse.ve.internal.swt.GridLayoutEditPolicy.eraseGridFi gure(GridLayoutEditPolicy.java:322)
at org.eclipse.ve.internal.swt.GridLayoutEditPolicy$2.run(GridL ayoutEditPolicy.java:407)
... 18 more
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:51:25.734
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:51:25.734
!MESSAGE Figure is not a child
!STACK 0
at org.eclipse.ve.internal.swt.GridLayoutEditPolicy.gridVisibil ityChanged(GridLayoutEditPolicy.java:423)
at org.eclipse.ve.internal.swt.GridLayoutEditPolicy$3.selectedS tateChanged(GridLayoutEditPolicy.java:528)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.primDeselect All(AbstractEditPartViewer.java:439)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.select(Abstr actEditPartViewer.java:563)
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:51:25.781
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:51:25.781
!STACK 0
... 18 more
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:51:36.656
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:51:36.656
!STACK 0
... 18 more
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:52:11.546
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:52:11.546
!STACK 0
at org.eclipse.gef.tools.SelectEditPartTracker.performSelection (SelectEditPartTracker.java:213)
at org.eclipse.gef.tools.SelectEditPartTracker.performCondition alSelection(SelectEditPartTracker.java:159)
at org.eclipse.gef.tools.SelectEditPartTracker.handleButtonDown (SelectEditPartTracker.java:90)
at org.eclipse.gef.tools.AbstractTool.mouseDown(AbstractTool.ja va:964)
at org.eclipse.gef.tools.SelectionTool.mouseDown(SelectionTool. java:491)
at org.eclipse.gef.EditDomain.mouseDown(EditDomain.java:215)
at org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Pressed(DomainEventDispatcher.java:342)
at org.eclipse.draw2d.LightweightSystem$EventHandler.mouseDown( LightweightSystem.java:522)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:133)
!ENTRY org.eclipse.ui 4 4 2006-01-31 15:52:29.734
!ENTRY org.eclipse.ui 4 0 2006-01-31 15:52:29.734
!MESSAGE 7
!STACK 0
java.lang.ArrayIndexOutOfBoundsException: 7
at org.eclipse.ve.internal.swt.GridLayoutPolicyHelper.findNextV alidObject(GridLayoutPolicyHelper.java:1334)
at org.eclipse.ve.internal.swt.GridLayoutPolicyHelper.createFil lerLabelsForDeletedControlCommands(GridLayoutPolicyHelper.ja va:1064)
at org.eclipse.ve.internal.swt.GridLayoutPolicyHelper.getFiller LabelsForDeletedControlCommands(GridLayoutPolicyHelper.java: 1036)
at org.eclipse.ve.internal.swt.GridLayoutEditPolicy.getDeleteDe pendantCommand(GridLayoutEditPolicy.java:568)
at org.eclipse.gef.editpolicies.LayoutEditPolicy.getCommand(Lay outEditPolicy.java:184)
at org.eclipse.gef.editpolicies.ConstrainedLayoutEditPolicy.get Command(ConstrainedLayoutEditPolicy.java:152)
at org.eclipse.ve.internal.swt.GridLayoutEditPolicy.getCommand( GridLayoutEditPolicy.java:238)
at org.eclipse.gef.editparts.AbstractEditPart.getCommand(Abstra ctEditPart.java:485)
at org.eclipse.ve.internal.cde.core.DefaultComponentEditPolicy. createDeleteCommand(DefaultComponentEditPolicy.java:33)
at org.eclipse.gef.editpolicies.ComponentEditPolicy.getDeleteCo mmand(ComponentEditPolicy.java:67)
at org.eclipse.gef.editpolicies.ComponentEditPolicy.getCommand( ComponentEditPolicy.java:56)
at org.eclipse.ve.internal.java.core.CutJavaBeanAction.calculat eEnabled(CutJavaBeanAction.java:56)
at org.eclipse.gef.ui.actions.WorkbenchPartAction.isEnabled(Wor kbenchPartAction.java:111)
at org.eclipse.ui.texteditor.RetargetTextEditorAction.setAction (RetargetTextEditorAction.java:188)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$4.focusGained(JavaVisualEditorPart.java:2418)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:105)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:848)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java: 1841)
at org.eclipse.swt.widgets.Widget.wmSetFocus(Widget.java:1961)
at org.eclipse.swt.widgets.Control.WM_SETFOCUS(Control.java:363 0)
at org.eclipse.swt.widgets.Canvas.WM_SETFOCUS(Canvas.java:247)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3102 )
at org.eclipse.swt.internal.win32.OS.SetFocus(Native Method)
at org.eclipse.swt.widgets.Control.forceFocus(Control.java:651)
at org.eclipse.swt.widgets.Control.setSavedFocus(Control.java:2 360)
at org.eclipse.swt.widgets.Decorations.restoreFocus(Decorations .java:806)
at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations. java:1623)
at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:1476)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3036 )
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1582)
at org.eclipse.swt.internal.win32.OS.DestroyWindow(Native Method)
at org.eclipse.swt.widgets.Control.destroyWidget(Control.java:5 27)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:383)
at org.eclipse.swt.widgets.Decorations.dispose(Decorations.java :441)
at org.eclipse.swt.widgets.Shell.dispose(Shell.java:499)
at org.eclipse.jface.window.Window.close(Window.java:321)
at org.eclipse.jface.dialogs.Dialog.close(Dialog.java:891)
at org.eclipse.ve.internal.java.core.AbstractRenameInstanceDial og.close(AbstractRenameInstanceDialog.java:244)
at org.eclipse.jface.dialogs.Dialog.okPressed(Dialog.java:856)
at org.eclipse.jface.dialogs.Dialog.buttonPressed(Dialog.java:4 09)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at org.eclipse.ve.internal.java.core.NameInMemberPropertyDescri ptor.getUniqueNamesInComposition(NameInMemberPropertyDescrip tor.java:260)
at org.eclipse.ve.internal.cde.properties.AddAnnotationsWithNam e.getAdditionalCommands(AddAnnotationsWithName.java:69)
at org.eclipse.ve.internal.cde.commands.AddAnnotationsCommand.e xecute(AddAnnotationsCommand.java:68)
at org.eclipse.ve.internal.propertysheet.common.commands.Compou ndCommand.appendAndExecute(CompoundCommand.java:414)
at org.eclipse.ve.internal.cde.commands.CommandBuilder.internal Append(CommandBuilder.java:314)
at org.eclipse.ve.internal.cde.commands.CommandBuilder.append(C ommandBuilder.java:98)
at org.eclipse.ve.internal.java.vce.rules.VCEPreSetCommand.hand leAnnotation(VCEPreSetCommand.java:410)
at org.eclipse.ve.internal.java.vce.rules.VCEPreSetCommand.hand leValue(VCEPreSetCommand.java:381)
at org.eclipse.ve.internal.java.vce.rules.VCEPreSetCommand.exec ute(VCEPreSetCommand.java:121)
at org.eclipse.ve.internal.propertysheet.common.commands.Compou ndCommand.execute(CompoundCommand.java:217)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorCommandStack$1.run(JavaVisualEditorCommandStack.java:52)
at org.eclipse.ve.internal.cde.core.ModelChangeController.doMod elChanges(ModelChangeController.java:166)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorCommandStack.execute(JavaVisualEditorCommandStack.java:4 9)
at org.eclipse.gef.tools.AbstractTool.executeCommand(AbstractTo ol.java:388)
at org.eclipse.gef.tools.AbstractTool.executeCurrentCommand(Abs tractTool.java:400)
at org.eclipse.gef.tools.CreationTool.performCreation(CreationT ool.java:254)
Re: ve creates widgets by itself [message #116464 is a reply to message #116447] Tue, 31 January 2006 13:10 Go to previous messageGo to next message
Can you please state the exact steps you did to reproduce this problem?
Note: With SWT GridLayout, the VE inserts blank labels as spacers within
empty cells so that your widgets can be placed in the exact locations
you specify. These blank labels are added/removed to create the layout
you specify. Are these the widgets you are talking about, or are you
seeing something else?
- Jeff
Re: ve creates widgets by itself [message #116480 is a reply to message #116447] Tue, 31 January 2006 13:48 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Most of your errors are due to cache problems. I explained in another
post to you just a few minutes ago how to clear the cache.
Rich Kulp
Re: ve creates widgets by itself [message #116484 is a reply to message #116464] Tue, 31 January 2006 13:53 Go to previous messageGo to next message
Jeff Myers escreveu:
> - Jeff
Hi Jeff,
I'm talking about exactly these widgets, but it doesn't make much sense
for me. Why should it be created ? It cannot be considered as empty
spaces ? Why should I keep in my Shell an object that will never be
used, just occupying disk and memory space for nothing ?
I don't know if I have enough technical knowledge to discuss it with
you, but I believe that it can have another solution.
I'd like you don't be mad with me, but I had a little experience with
another IDE that has a good customizer for GridBagLayout ( I prefer
don't say names...), and it don't have this behavior.
The reason we're changing to Eclipse is that SWT seems to be the best
solution for our desktop projects, and we'd like to take full advantage
of Visual Editor.
Thank you very much.
Alexandre
Re: ve creates widgets by itself [message #116490 is a reply to message #116484] Tue, 31 January 2006 13:58 Go to previous messageGo to next message
GridLayout requires them. There is no way to get your grid to look like
the way you want without them. This is because GridLayout works on
ZOrder to determine where to put things. You can't just say I want a
control to be in grid (2,2). To get into grid (2,2) you need to have a
set of controls BEFORE that control which fill in grid (0,0) to grid (2,1).
This is not a VE problem. It is the way SWT GridLayout works. AWT's
GridBagLayout did allow you to say exactly what grid to put them in, SWT
GridLayout doesn't.
Rich Kulp
Re: ve creates widgets by itself [message #116503 is a reply to message #116490] Tue, 31 January 2006 14:38 Go to previous messageGo to next message
Rich Kulp escreveu:
> GridLayout doesn't.
Ok. I understand. I forgot we're talking about SWT GridLayout and not
AWT GridBagLayout. Sorry.
I'll work hard to create a good project with these resources.
Thank you.
Re: ve creates widgets by itself [message #116510 is a reply to message #116480] Tue, 31 January 2006 14:40 Go to previous message
Rich Kulp escreveu:
Oh! So it will solve this problem too ? I'll test.
The problem with Menu is solved.
Thanks.
Re: ve creates widgets by itself [message #611909 is a reply to message #115947] Tue, 31 January 2006 12:59 Go to previous message
> Hi again,
> being moved.
> Why it happens ?
> Thanks.
with them too.
Thank you.
!STACK 0
... 18 more
!STACK 0
... 18 more
!STACK 0
... 18 more
!STACK 0
!STACK 0
!STACK 0
... 18 more
!MESSAGE 2
!STACK 0
!MESSAGE 2
!STACK 0
!MESSAGE 2
!STACK 0
!MESSAGE 2
!STACK 0
!MESSAGE 2
!STACK 0
!STACK 0
... 18 more
!STACK 0
!STACK 0
... 18 more
!STACK 0
... 18 more
!STACK 0
!MESSAGE 7
!STACK 0
at org.eclipse.
Re: ve creates widgets by itself [message #611911 is a reply to message #116447] Tue, 31 January 2006 13:10 Go to previous message
- Jeff
Re: ve creates widgets by itself [message #611914 is a reply to message #116447] Tue, 31 January 2006 13:48 Go to previous message
Rich Kulp
Re: ve creates widgets by itself [message #611915 is a reply to message #116464] Tue, 31 January 2006 13:53 Go to previous message
> - Jeff
Hi Jeff,
of Visual Editor.
Alexandre
Re: ve creates widgets by itself [message #611916 is a reply to message #116484] Tue, 31 January 2006 13:58 Go to previous message
GridLayout doesn't.
Rich Kulp
Re: ve creates widgets by itself [message #611918 is a reply to message #116490] Tue, 31 January 2006 14:38 Go to previous message
Rich Kulp escreveu:
> GridLayout doesn't.
Thank you.
Re: ve creates widgets by itself [message #611919 is a reply to message #116480] Tue, 31 January 2006 14:40 Go to previous message
Rich Kulp escreveu:
Thanks.
Previous Topic:SWT Menubar
Next Topic:JFace +EMF binding?
Current Time: Tue Oct 28 10:14:39 EDT 2025
Powered by FUDForum. Page generated in 0.09484 seconds
