JNDI-Context on Tomcat 5.5 [message #115942] |
Tue, 16 December 2008 11:48  |
I want to deploy my RAP app on an external server (Tomcat 5.5) using the
equinox servlet bridge. I need to instantiate the quartz scheduler and
have it to be communicating with a derby database, but I'm not able to
initialize the context (see the exception beneath).
Here is what I've already tried (without success):
- adding a folder "META-INF" to server-directory on the same level as my
project's WEB-INF-folder; this contains a "context.xml" where the context
is defined
- same context.xml renamed as myproject.xml copied into
jakarta-tomcat-5.5.9\conf\Catalina\localhost
- jakarta-tomcat-5.5.9\conf\server.xml: adding a resource with the
connection properties under "<GlobalNamingResources>"
- adding following code to my project's web.xml:
<resource-ref>
<description>Supplycare DB</description>
<res-ref-name>jdbc/quartz</res-ref-name>
<res-type>javax.sql.DataSource</res-type>
<res-auth>Container</res-auth>
</resource-ref>
here the jndi url that is given to the quartz-constructor with a few other
properties:
org.quartz.jobStore.dataSource = quartzDS1
org.quartz.dataSource.quartzDS1.jndiURL = java:comp/env/jdbc/quartz
The database is working fine in other (non-RAP) projects. Is it possible,
that the context is overwritten by any RAP-feature?
Thanks for your help.
Regards, Alex
ERROR JNDIConnectionProvider:129 - Error looking up datasource: Name
java:comp is not bound in this Context
javax.naming.NameNotFoundException: Name java:comp is not bound in this
Context
at org.apache.naming.NamingContext.lookup(NamingContext.java:76 9)
at org.apache.naming.NamingContext.lookup(NamingContext.java:15 2)
at javax.naming.InitialContext.lookup(InitialContext.java:392)
org.quartz.utils.JNDIConnectionProvider.init(JNDIConnectionP rovider.java:127)
org.quartz.utils.JNDIConnectionProvider.<init>(JNDIConnectionProvider.java:105)
org.quartz.impl.StdSchedulerFactory.instantiate(StdScheduler Factory.java:917)
org.quartz.impl.StdSchedulerFactory.getScheduler(StdSchedule rFactory.java:1355)
scheduler.service.CommonSchedulerService.initializeScheduler (CommonSchedulerService.java:91)
scheduler.service.SchedulerControlService.initializeSchedule r(SchedulerControlService.java:55)
scheduler.service.CommonSchedulerService.<init>(CommonSchedulerService.java:78)
scheduler.service.SchedulerControlService.<init>(SchedulerControlService.java:34)
rap.SchedServCommunicationImpl.initScheduler(SchedServCommun icationImpl.java:82)
at rap.BorderLayoutView.createPartControl(BorderLayoutView.java :80)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:371)
org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:230)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:31 2)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:53 6)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:180)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:265)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:64)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:478)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1260)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1213)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 13)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:651)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:577)
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:569)
org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:269)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:930)
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:2498)
org.eclipse.ui.internal.WorkbenchWindow$22.run(WorkbenchWind ow.java:2832)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:66)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:2813)
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:718)
org.eclipse.ui.internal.Workbench$18.runWithException(Workbe nch.java:976)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:32)
org.eclipse.rwt.internal.lifecycle.UICallBackManager.addSync (UICallBackManager.java:135)
at org.eclipse.swt.widgets.Display$2.run(Display.java:649)
org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler. runNonUIThreadWithFakeContext(UICallBackServiceHandler.java: 423)
org.eclipse.rwt.lifecycle.UICallBack.runNonUIThreadWithFakeC ontext(UICallBack.java:44)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:647)
org.eclipse.ui.internal.StartupThreading.runWithWorkbenchExc eptions(StartupThreading.java:55)
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:972)
org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.java:1793)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1729)
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:188)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:790)
org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1335)
org.eclipse.ui.internal.StartupThreading.runWithoutException s(StartupThreading.java:110)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1330)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:425)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:408)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:157)
at rap.SchedServGui.createUI(SchedServGui.java:13)
org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:228)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:116)
at java.lang.Thread.run(Thread.java:619)
FUDForum. Page generated in 0.03263 seconds
