| [Teneo] NoSuchMethodError exception when trying to add element to an EList [message #115924] |
Wed, 26 March 2008 14:30  |
Originally posted by: vnikolov.us.ibm.com
Hello Martin,
I get an exception while trying to add an element in a featuremap. I was
wondering if you can give me some hints what may be the problem? Or at
least to point me where I should start looking for the reason for the
problem?
Here is the exception trace:
Nested Exception is java.lang.NoSuchMethodError:
org/eclipse/emf/teneo/mapping/elist/PersistableFeatureMap.in verseAdd(Lorg/eclipse/emf/ecore/util/FeatureMap$Entry;Lorg/e clipse/emf/common/notify/NotificationChain;)Lorg/eclipse/emf /common/notify/NotificationChain;
org.eclipse.emf.teneo.mapping.elist.PersistableFeatureMap.di dAdd(PersistableFeatureMap.java:216)
org.eclipse.emf.teneo.jpox.elist.FeatureMapWrapper.didAdd(Fe atureMapWrapper.java:558)
org.eclipse.emf.teneo.mapping.elist.PersistableFeatureMap.di dAdd(PersistableFeatureMap.java:1)
org.eclipse.emf.common.util.DelegatingEList.addUnique(Delega tingEList.java:498)
org.eclipse.emf.common.notify.impl.DelegatingNotifyingListIm pl.doAddUnique(DelegatingNotifyingListImpl.java:315)
org.eclipse.emf.common.notify.impl.DelegatingNotifyingListIm pl.addUnique(DelegatingNotifyingListImpl.java:299)
org.eclipse.emf.ecore.util.DelegatingFeatureMap.addUnique(De legatingFeatureMap.java:1381)
org.eclipse.emf.common.util.DelegatingEList.add(DelegatingEL ist.java:479)
org.eclipse.emf.ecore.util.DelegatingFeatureMap.doAdd(Delega tingFeatureMap.java:521)
org.eclipse.emf.ecore.util.DelegatingFeatureMap.add(Delegati ngFeatureMap.java:1135)
org.eclipse.emf.ecore.util.FeatureMapUtil$FeatureEList.add(F eatureMapUtil.java:646)
Here is the XMLSchema with the respective elements. I'm trying to add
square object into an shape list.
<xs:element name="shape" type="lib:Shape" abstract="true"/>
<xs:complexType name="Shape" abstract="true">
<!-- some elements and attributes --> </xs:complexType>
<xs:element name="square" type="lib:Square" substitutionGroup="lib:shape" />
<xs:complexType name="Square">
<xs:complexContent>
<xs:extension base="lib:Shape">
<xs:sequence>
<!-- some additional elements-->
</xs:sequence>
</xs:extension>
</xs:complexContent>
</xs:complexType>
Thanks in advance!
Vladimir
| Re: [Teneo] NoSuchMethodError exception when trying to add element to an EList [message #116092 is a reply to message #116078] |
Thu, 27 March 2008 05:46  |
Hi Vladimir,
For Teneo 0.8.0 you need EMF 2.3 or 2.4, Teneo 0.7.5 is for emf 2.2, I would advice to upgrade as
0.7.5 is not maintained actively.
gr. Martin
Vladimir Nikolov wrote:
> Hello Martin,
> Thanks for the response.
> My Teneo version is : 0.8.0.v200802122150
> My EMF version is : 2.2.1.v200609210005
> Vladimir
> Martin Taal wrote:
>> Hi Vladimir,
>> The inverseAdd method is implemented in the superclass of
>> PersistableFeatureMap: org.eclipse.emf.ecore.util.DelegatingFeatureMap
>> So it seems that the emf jar's you are using are different from the
>> ones assumed by Teneo.
>> Which Teneo version and which EMF version are you using?
>> gr. Martin
>>> Hello Martin,
>>> was wondering if you can give me some hints what may be the problem?
>>> Or at least to point me where I should start looking for the reason
>>> for the problem?
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> </xs:complexType> <xs:element name="square" type="lib:Square"
>>> <xs:complexContent>
>>> <xs:sequence>
>>> </xs:sequence>
>>> </xs:extension>
>>> </xs:complexType>
>>> Thanks in advance!
>>> Vladimir
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: [Teneo] NoSuchMethodError exception when trying to add element to an EList [message #615994 is a reply to message #115924] |
Wed, 26 March 2008 15:07  |
Hi Vladimir,
The inverseAdd method is implemented in the superclass of PersistableFeatureMap:
So it seems that the emf jar's you are using are different from the ones assumed by Teneo.
gr. Martin
> Hello Martin,
> problem?
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> Thanks in advance!
> Vladimir
The Netherlands
| Re: [Teneo] NoSuchMethodError exception when trying to add element to an EList [message #616005 is a reply to message #115936] |
Thu, 27 March 2008 05:37  |
Hello Martin,
Vladimir
Martin Taal wrote:
> Hi Vladimir,
> assumed by Teneo.
> gr. Martin
>> Hello Martin,
>> for the problem?
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> <xs:complexContent>
>> <xs:sequence>
>> </xs:sequence>
>> </xs:extension>
>> </xs:complexType>
>> Thanks in advance!
>> Vladimir
| Re: [Teneo] NoSuchMethodError exception when trying to add element to an EList [message #616006 is a reply to message #116078] |
Hi Vladimir,
gr. Martin
> Hello Martin,
> Vladimir
> Martin Taal wrote:
>> Hi Vladimir,
>> gr. Martin
>>> Hello Martin,
>>> for the problem?
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> <xs:complexContent>
>>> <xs:sequence>
>>> </xs:sequence>
>>> </xs:extension>
>>> </xs:complexType>
>>> Thanks in advance!
>>> Vladimir
The Netherlands
FUDForum. Page generated in 0.04897 seconds
