Home » Modeling » GMF (Graphical Modeling Framework) » GMF Filename - passing it down to model attribute.
GMF Filename - passing it down to model attribute. [message #115922] Mon, 02 April 2007 01:06 Go to next message
Originally posted by: evaandoli.dodo.com.au
I'd like to pass the filename from the creation wizard down to an attribute
in the model.
I look at the creation wizard classes but must admit I'm struggling to see
where it creates the model impl.
I also puts break points in the model create but looking back up the stack I
can't see the filename anywhere.
I'm sure its there just a few pointers would help thanks,
Stu
Re: GMF Filename - passing it down to model attribute. [message #122086 is a reply to message #115922] Fri, 27 April 2007 02:57 Go to previous messageGo to next message
Originally posted by: renwart.lippmann.lu
Stu a écrit :
> in the model.
> Stu
Hello, I'd like to do the same as you, but I don't know where (and how?)
the "diagram name" (with full path if possible) is accessible in the
model Impl classes...
Did you find some interesting things for that problem ?
Thanks ,
benren.
Re: GMF Filename - passing it down to model attribute. [message #122097 is a reply to message #122086] Fri, 27 April 2007 03:30 Go to previous messageGo to next message
Sorry mate, it was a low priority for me and I never got around to it for my
version 1.
I do need to address it though.
Let me know how you go.
Stu
"Ben Renwart" <renwart@lippmann.lu> wrote in message
news:f0s6ov$vjr$1@build.eclipse.org...
> Stu a
<solved>Re: GMF Filename - passing it down to model attribute. [message #123317 is a reply to message #115922] Wed, 02 May 2007 08:07 Go to previous message
I finally got around to spending too much time on this and came up with the
following solution:-
Look at class (replace YourDiagramDomain with yours)
<YourDiagramDomain>DiagramEditorUtil
It contains a method called:-
createDiagram(
Which itself contains a method called:-
protected CommandResult doExecuteWithResult(
In here you get access to the top level model created.
So you can do somthing like:-
model.setName(modelURI.path());
Anyway that is how I did it,
Stuart
"Stu" <evaandoli@dodo.com.au> wrote in message
news:euq30h$jeg$1@build.eclipse.org...
> attribute in the model.
> I can't see the filename anywhere.
> Stu
Previous Topic:Passing the diagram filename to a model element property ??
Next Topic:Tracking add child event fired from popup bar, before model is updated.
Current Time: Fri Jul 25 23:29:15 EDT 2025
Powered by FUDForum. Page generated in 0.04703 seconds
