Home » Modeling » GMF (Graphical Modeling Framework) » Defaults from ECORE model don't appear in XML data from diagram.
| Defaults from ECORE model don't appear in XML data from diagram. [message #115906] |
Mon, 02 April 2007 01:00  |
Originally posted by: evaandoli.dodo.com.au
Not sure if this is a bug or not.
I have put a default in the ecore model for an attribute, its appears in
the diagram ok BUT doesn't appear in the XML data output from the diagram.
I'm guessing its because the attribute changed event is never generated so
its not expected to be anything other that it's initial value.
I would like all attibutes to appear in the XML data output from the diagram
event if they do not have a value - is that easy to do ?
Stuart
| Re: Defaults from ECORE model don't appear in XML data from diagram. [message #116349 is a reply to message #116287] |
Mon, 02 April 2007 11:08   |
------=_NextPart_000_004F_01C7758C.8EC7D2C0
Content-Type: text/plain;
charset="iso-8859-1"
Ed,
Sorry mate, still struggling here with this one.
Maybe a code example would help.
Im at the createResource(URI) method in the =
<myProject>ResourceFactoryImpl but not sure what to do to include this =
save option.
Stu
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:eur3af$hs3$1@build.eclipse.org...
Stu,
You can override the createResource method of the =
XyzResourceFactoryImpl to include this as a default save option.
Stu wrote:=20
Ed,
Thanks for the reply. I see I have a ResourceImpl which is specific for =
my=20
project but how do I use this save option you mention below?
"Ed Merks" <merks@ca.ibm.com> wrote in message=20
news:euqps3$55v$2@build.eclipse.org...
Stu,
Features for which eIsSet returns false will not be serialized so=20
generally default values will not be serialized. You can use the save=20
option XMLResource.OPTION_KEEP_DEFAULT_CONTENT to force them to be=20
serialized.
I have put a default in the ecore model for an attribute, its appears =
in=20
the diagram ok BUT doesn't appear in the XML data output from the=20
diagram.
I'm guessing its because the attribute changed event is never generated=20
so its not expected to be anything other that it's initial value.
I would like all attibutes to appear in the XML data output from the=20
diagram event if they do not have a value - is that easy to do ?
Stuart
=20
=20
Content-Type: text/html;
<HTML><HEAD>
<META content=3D"MSHTML 6.00.6000.16414" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Sorry mate, still struggling here with =
this=20
one.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Maybe a code example would =
help.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Im at the createResource(URI) method in =
the=20
<myProject>ResourceFactoryImpl but not sure what to do to include =
this=20
save option.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Stu</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:eur3af$hs3$1@build.eclipse.org">news:eur3af$hs3$1@build.ecli=
pse.org</A>...</DIV>Stu,<BR><BR>You=20
can override the createResource method of the XyzResourceFactoryImpl =
to=20
include this as a default save option.<BR><BR><BR>Stu wrote:=20
<BLOCKQUOTE cite=3Dmideur2vb$gvf$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Ed,
my=20
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:merks@ca.ibm.com"><merks@ca.ibm.com></A> wrote in =
message=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:euqps3$55v$2@build.eclipse.org">news:euqps3$55v$2@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Stu,
serialized.
Stu wrote:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Not sure if this is a bug =
or not.
in=20
diagram.
Stuart
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_004F_01C7758C.8EC7D2C0--
| Re: Defaults from ECORE model don't appear in XML data from diagram. [message #116364 is a reply to message #116349] |
Mon, 02 April 2007 14:13   |
--------------010900090300010209020404
Stu,
Like this:
* Creates an instance of the resource.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated *NOT*
public Resource createResource(URI uri)
XMLResource result = new LibraryResourceImpl(uri);
*result.getDefaultSaveOptions().put(XMLResource.OPTION_KEEP_ DEFAULT_CONTENT,
Boolean.TRUE);*
result.getDefaultSaveOptions().put(XMLResource.OPTION_EXTEND ED_META_DATA,
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_EXTEND ED_META_DATA,
Boolean.TRUE);
result.getDefaultSaveOptions().put(XMLResource.OPTION_SCHEMA _LOCATION,
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_EN CODED_ATTRIBUTE_STYLE,
Boolean.TRUE);
result.getDefaultSaveOptions().put(XMLResource.OPTION_USE_EN CODED_ATTRIBUTE_STYLE,
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_LE XICAL_HANDLER,
Boolean.TRUE);
return result;
Stu wrote:
> Ed,
> save option.
> Stu
> "Ed Merks" <merks@ca.ibm.com <mailto:merks@ca.ibm.com>> wrote in
> message news:eur3af$hs3$1@build.eclipse.org...
> Stu,
> Stu wrote:
>> Ed,
>> Thanks for the reply. I see I have a ResourceImpl which is specific for my
>>> Stu,
>>> serialized.
>>>> diagram.
>>>> Stuart
<html>
<head>
</head>
Stu,<br>
<br>
Like this:<br>
<blockquote><small> /**</small><br>
<small> * Creates an instance of the resource.</small><br>
<small> * <!-- begin-user-doc --></small><br>
<small> * <!-- end-user-doc --></small><br>
<small> * @generated <b>NOT</b></small><br>
<small> */</small><br>
<small> @Override</small><br>
<small> public Resource createResource(URI uri)</small><br>
<small> {</small><br>
<small> XMLResource result = new LibraryResourceImpl(uri);</small><br>
<small> <b> result.getDefaultSaveOptions().put(XMLResource.OPTION_KEEP_D EFAULT_CONTENT,
Boolean.TRUE);</b></small><br>
<small> </small><br>
<small>
Boolean.TRUE);</small><br>
<small>
<br>
<small>
<br>
<small>
<small>
<br>
<small>
<small> return result;</small><br>
<small> }</small><br>
</blockquote>
<br>
Stu wrote:
<blockquote cite="mideur693$ao9$1@build.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.6000.16414" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">Ed,</font></div>
<div><font face="Arial" size="2">Sorry mate, still struggling here
with this one.</font></div>
<div><font face="Arial" size="2">Maybe a code example would help.</font></div>
<div> </div>
<div><font face="Arial" size="2">Im at the createResource(URI) method
in the <myProject>ResourceFactoryImpl but not sure what to do to
include this save option.</font></div>
<div> </div>
<div><font face="Arial" size="2">Stu</font></div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Ed Merks" <<a href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>>
wrote in message <a href="news:eur3af$hs3$1@build.eclipse.org">news:eur3af$hs3$1@build.eclipse.org</a>...</div>
Stu,<br>
<br>
XyzResourceFactoryImpl to include this as a default save option.<br>
<br>
<br>
Stu wrote:
<blockquote cite="mideur2vb$gvf$1@build.eclipse.org" type="cite">
<pre wrap="">Ed,
"Ed Merks" <a class="moz-txt-link-rfc2396E"
href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext"
href="news:euqps3$55v$2@build.eclipse.org">news:euqps3$55v$2@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Stu,
serialized.
Stu wrote:
</pre>
<pre wrap="">Not sure if this is a bug or not.
diagram.
Stuart
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------010900090300010209020404--
| Re: Defaults from ECORE model don't appear in XML data from diagram. [message #116374 is a reply to message #116364] |
Mon, 02 April 2007 23:10   |
------=_NextPart_000_000B_01C775F1.7A522380
Ok.
I have my <project>ResourceImpl
and it already overrides the createResource method and create a =
Resource.
See below:-
* @generated
public Resource createResource(URI uri) {
Resource result =3D new RulesstepbystepmodelResourceImpl(uri);
return result;
I replace this with:-
* @generated NOT
XMLResource result =3D new RulesstepbystepmodelResourceImpl(uri);
result.getDefaultSaveOptions().put(XMLResource.OPTION_KEEP_D EFAULT_CONTEN=
T, Boolean.TRUE);
return result;
I regenerate the diagram code (not sure I need to but I did), and =
launched the plugin test.
I create a new diagram and add a node and save (the defaults appear on =
the diagram as expected - these were setup in the ECORE file)
I check the XML Data file for the diagram and the defaults are not in =
there.
Is there something I can missing here,
Stuart
news:eurh3g$9r0$2@build.eclipse.org...
Stu,
Like this:
* @generated NOT
XMLResource result =3D new LibraryResourceImpl(uri);
T, Boolean.TRUE);
=20
result.getDefaultSaveOptions().put(XMLResource.OPTION_EXTEND ED_META_DATA,=
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_EXTEND ED_META_DATA,=
Boolean.TRUE);
result.getDefaultSaveOptions().put(XMLResource.OPTION_SCHEMA _LOCATION, =
Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_EN CODED_ATTRIBU=
TE_STYLE, Boolean.TRUE);
result.getDefaultSaveOptions().put(XMLResource.OPTION_USE_EN CODED_ATTRIBU=
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_LE XICAL_HANDLER=
, Boolean.TRUE);
return result;
Stu wrote:=20
Ed,
save option.
Stu
Stu,
Stu wrote:=20
Ed,
my=20
Stu,
serialized.
in=20
diagram.
Stuart
=20
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.6000.16414" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2>Ok.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I have my =
<project>ResourceImpl</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>and it already overrides the =
createResource method=20
and create a Resource.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>See below:-</FONT></DIV>
<DIV><FONT size=3D2>
<P align=3Dleft></FONT><FONT color=3D#3f5fbf =
size=3D2>/**</P></FONT><FONT size=3D2>
<P align=3Dleft></FONT><FONT color=3D#3f5fbf size=3D2>*</FONT><FONT =
size=3D2>=20
</FONT><FONT color=3D#3f5fbf size=3D2>Creates</FONT><FONT size=3D2> =
</FONT><FONT=20
color=3D#3f5fbf size=3D2>an</FONT><FONT size=3D2> </FONT><FONT =
color=3D#3f5fbf=20
size=3D2>instance</FONT><FONT size=3D2> </FONT><FONT color=3D#3f5fbf=20
size=3D2>of</FONT><FONT size=3D2> </FONT><FONT color=3D#3f5fbf =
size=3D2>the</FONT><FONT=20
size=3D2>resource.</P></FONT><FONT size=3D2>
size=3D2>=20
</FONT><FONT color=3D#3f5fbf size=3D2><!-- begin-user-doc =
--></P></FONT><FONT=20
size=3D2>
size=3D2>=20
</FONT><FONT color=3D#3f5fbf size=3D2><!-- end-user-doc =
size=3D2>
size=3D2>=20
</FONT><B><FONT color=3D#7f9fbf size=3D2>@generated</P></B></FONT><FONT =
size=3D2>
<P align=3Dleft></FONT><FONT color=3D#3f5fbf size=3D2>*/</P></FONT><FONT =
size=3D2>
<P align=3Dleft></FONT><FONT color=3D#646464 =
size=3D2>@Override</P></FONT><FONT=20
size=3D2>
<P align=3Dleft></FONT><B><FONT color=3D#7f0055 =
size=3D2>public</B></FONT><FONT=20
size=3D2> Resource createResource(URI uri) {</P>
<P align=3Dleft>Resource result =3D </FONT><B><FONT color=3D#7f0055=20
size=3D2>new</B></FONT><FONT size=3D2> =
RulesstepbystepmodelResourceImpl(uri);</P>
size=3D2>return</B></FONT><FONT=20
size=3D2> result;</P>
<P align=3Dleft>}</P>
<P align=3Dleft>I replace this with:-</P><FONT size=3D2>
size=3D2>=20
</FONT><FONT=20
color=3D#3f5fbf=20
size=3D2>=20
size=3D2>
size=3D2>=20
size=3D2>
size=3D2>=20
</FONT><B><FONT color=3D#7f9fbf size=3D2>@generated =
NOT</P></B></FONT><FONT size=3D2>
size=3D2>
size=3D2>
<P align=3Dleft>XMLResource result =3D </FONT><B><FONT color=3D#7f0055=20
size=3D2>new</B></FONT><FONT size=3D2>=20
RulesstepbystepmodelResourceImpl(uri);</FONT></P>
<P align=3Dleft><FONT size=3D2><FONT face=3DArial><FONT=20
face=3D"Times New Roman"> =20
<B> result.getDefaultSaveOptions().put(XMLResource.OPTION_KEEP_D EFAULT_CON=
TENT,=20
Boolean.TRUE);</B></FONT></FONT></P>
<P align=3Dleft><FONT face=3DArial>I regenerate the diagram code (not =
sure I need to=20
but I did), and launched the plugin test.</FONT></P>
<P align=3Dleft><FONT face=3DArial>I create a new diagram and add a node =
and save=20
(the defaults appear on the diagram as expected - these were setup in =
the ECORE=20
file)</FONT></P>
<P align=3Dleft><FONT face=3DArial>I check the XML Data file for the =
diagram and the=20
defaults are not in there.</FONT></P>
<P align=3Dleft><FONT face=3DArial>Is there something I can missing =
here,</FONT></P>
<P align=3Dleft><FONT face=3DArial>Stuart</FONT></P></FONT></FONT></DIV>
<BLOCKQUOTE=20
href=3D"news:eurh3g$9r0$2@build.eclipse.org">news:eurh3g$9r0$2@build.ecli=
pse.org</A>...</DIV>Stu,<BR><BR>Like=20
this:<BR>
<BLOCKQUOTE><SMALL> /**</SMALL><BR><SMALL> * Creates =
an=20
instance of the resource.</SMALL><BR><SMALL> * <!--=20
begin-user-doc --></SMALL><BR><SMALL> * <!-- =
end-user-doc=20
--></SMALL><BR><SMALL> * @generated=20
<B>NOT</B></SMALL><BR><SMALL> =
*/</SMALL><BR><SMALL> =20
@Override</SMALL><BR><SMALL> public Resource =
createResource(URI=20
uri)</SMALL><BR><SMALL> {</SMALL><BR><SMALL> =
XMLResource result =3D new=20
LibraryResourceImpl(uri);</SMALL><BR><SMALL> =20
TENT,=20
Boolean.TRUE);</B></SMALL><BR><SMALL> =20
=20
Boolean.TRUE);</SMALL><BR><SMALL> =20
=20
Boolean.TRUE);</SMALL><BR><BR><SMALL> =20
result.getDefaultSaveOptions().put(XMLResource.OPTION_SCHEMA _LOCATION,=20
TE_STYLE,=20
TE_STYLE,=20
,=20
Boolean.TRUE);</SMALL><BR><SMALL> return=20
result;</SMALL><BR><SMALL> }</SMALL><BR></BLOCKQUOTE><BR>Stu =
wrote:=20
<BLOCKQUOTE cite=3Dmideur693$ao9$1@build.eclipse.org type=3D"cite">
<STYLE></STYLE>
<DIV><FONT face=3DArial size=3D2>Sorry mate, still struggling here =
with this=20
one.</FONT></DIV>
help.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Im at the createResource(URI) =
method in the=20
<myProject>ResourceFactoryImpl but not sure what to do to =
include this=20
<DIV> </DIV>
<BLOCKQUOTE=20
BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A=20
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>> wrote in =
message=20
<A=20
XyzResourceFactoryImpl to=20
my=20
message=20
pse.org</A>...
</PRE>
serialized.
Stu wrote:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Not sure if this is a =
bug or not.
in=20
diagram.
Stuart
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BLOCKQUOTE><BR></BLOCKQUOTE ></BODY>=
</HTML>
------=_NextPart_000_000B_01C775F1.7A522380--
| Re: Defaults from ECORE model don't appear in XML data from diagram. [message #116413 is a reply to message #116374] |
Tue, 03 April 2007 06:55  |
--------------080803090008060807090202
Stu,
Is this resource you've overridden actual being used to save your XML
data file? Check when the save happens that the option is actually set
in the resource's defaultSaveOptions map.
Stu wrote:
> Ok.
> and it already overrides the createResource method and create a Resource.
> See below:-
> * *@generated*
> @Override
> *public* Resource createResource(URI uri) {
> Resource result = *new* RulesstepbystepmodelResourceImpl(uri);
> *return* result;
> * *@generated NOT*
> @Override
> XMLResource result = *new* RulesstepbystepmodelResourceImpl(uri);
> Boolean.TRUE);*
> *return* result;
> there.
> Stuart
> message news:eurh3g$9r0$2@build.eclipse.org...
> Stu,
> Like this:
> * @generated *NOT*
> @Override
> Boolean.TRUE);*
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> return result;
> Stu wrote:
>> Ed,
>> this save option.
>> Stu
>> in message news:eur3af$hs3$1@build.eclipse.org...
>> Stu,
>> Stu wrote:
>>> Ed,
>>>> Stu,
>>>> serialized.
>>>>> diagram.
>>>>> Stuart
<html>
<head>
</head>
Stu,<br>
<br>
in the resource's defaultSaveOptions map.<br>
<br>
<br>
Stu wrote:
<blockquote cite="mideusgjk$9rc$1@build.eclipse.org" type="cite">
<div><font face="Arial" size="2">Ok.</font></div>
<div><font face="Arial" size="2">I have my <project>ResourceImpl</font></div>
<div><font face="Arial" size="2">and it already overrides the
createResource method and create a Resource.</font></div>
<div><font face="Arial" size="2">See below:-</font></div>
<div><font size="2">
</font>
<p align="left"><font color="#3f5fbf" size="2">/**</font></p>
<font size="2"></font>
<p align="left"><font color="#3f5fbf" size="2">*</font><font size="2">
</font><font color="#3f5fbf" size="2">Creates</font><font size="2"> </font><font
color="#3f5fbf" size="2">an</font><font size="2"> </font><font
color="#3f5fbf" size="2">instance</font><font size="2"> </font><font
color="#3f5fbf" size="2">of</font><font size="2"> </font><font
color="#3f5fbf" size="2">the</font><font size="2"> </font><font
color="#3f5fbf" size="2">resource.</font></p>
</font><font color="#3f5fbf" size="2"><!-- begin-user-doc --></font></p>
</font><font color="#3f5fbf" size="2"><!-- end-user-doc --></font></p>
</font><b><font color="#7f9fbf" size="2">@generated</font></b></p>
<p align="left"><font color="#3f5fbf" size="2">*/</font></p>
<p align="left"><font color="#646464" size="2">@Override</font></p>
<p align="left"><b><font color="#7f0055" size="2">public</font></b><font
size="2"> Resource createResource(URI uri) {</font></p>
<p align="left"><font size="2">Resource result = </font><b><font
color="#7f0055" size="2">new</font></b><font size="2">
RulesstepbystepmodelResourceImpl(uri);</font></p>
<p align="left"><b><font color="#7f0055" size="2">return</font></b><font
size="2"> result;</font></p>
<p align="left"><font size="2">}</font></p>
<p align="left"><font size="2">I replace this with:-</font></p>
<font size="2"><font size="2"></font></font>
<p align="left"><font size="2"><font color="#3f5fbf" size="2">/**</font></font></p>
<p align="left"><font size="2"><font color="#3f5fbf" size="2">*</font><font
size="2"> </font><font color="#3f5fbf" size="2">Creates</font><font
size="2"> </font><font color="#3f5fbf" size="2">an</font><font
size="2"> </font><font color="#3f5fbf" size="2">instance</font><font
size="2"> </font><font color="#3f5fbf" size="2">of</font><font
size="2"> </font><font color="#3f5fbf" size="2">the</font><font
size="2"> </font><font color="#3f5fbf" size="2">resource.</font></font></p>
size="2"> </font><font color="#3f5fbf" size="2"><!--
begin-user-doc --></font></font></p>
size="2"> </font><font color="#3f5fbf" size="2"><!-- end-user-doc
size="2"> </font><b><font color="#7f9fbf" size="2">@generated NOT</font></b></font></p>
<p align="left"><font size="2"><font color="#3f5fbf" size="2">*/</font></font></p>
<p align="left"><font size="2"><font color="#646464" size="2">@Override</font></font></p>
<p align="left"><font size="2"><b><font color="#7f0055" size="2">public</font></b><font
size="2"> Resource createResource(URI uri) {</font></font></p>
<p align="left"><font size="2"><font size="2">XMLResource result = </font><b><font
RulesstepbystepmodelResourceImpl(uri);</font></font></p>
<p align="left"><font size="2"><font size="2"><font face="Arial"><font
face="Times New Roman"> <b> result.getDefaultSaveOptions().put(XMLResource.OPTION_KEEP_D EFAULT_CONTENT,
Boolean.TRUE);</b></font></font></font></font></p>
<p align="left"><font size="2"><b><font color="#7f0055" size="2">return</font></b><font
size="2"> result;</font></font></p>
<p align="left"><font size="2"><font size="2">}</font></font></p>
<p align="left"><font size="2"><font size="2"><font face="Arial">I
launched the plugin test.</font></font></font></p>
the diagram as expected - these were setup in the ECORE file)</font></font></font></p>
there.</font></font></font></p>
<p align="left"><font size="2"><font size="2"><font face="Arial">Is
there something I can missing here,</font></font></font></p>
<p align="left"><font size="2"><font size="2"><font face="Arial">Stuart</font></font></font></p>
</div>
<blockquote
wrote in message <a href="news:eurh3g$9r0$2@build.eclipse.org">news:eurh3g$9r0$2@build.eclipse.org</a>...</div>
Stu,<br>
<br>
Like this:<br>
<small>
<small>
<br>
<small>
<br>
<small>
<small>
<br>
<small>
</blockquote>
<br>
<style></style>
here with this one.</font></div>
<div> </div>
method in the <myProject>ResourceFactoryImpl but not sure what to
do to include this save option.</font></div>
<div> </div>
<blockquote
Stu,<br>
<br>
<br>
<br>
<pre wrap="">Ed,
</pre>
<pre wrap="">Stu,
serialized.
Stu wrote:
</pre>
diagram.
Stuart
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------080803090008060807090202--
Current Time: Fri Nov 07 15:36:06 EST 2025
Powered by FUDForum. Page generated in 0.06826 seconds
