Home » Newcomers » Newcomers » java delete-history recap?
java delete-history recap? [message #115818] Wed, 09 November 2005 10:44 Go to next message
Originally posted by: v.niekerk.hccnet.nl
I'm programming in Java in Eclipse 3.1. I deleted a declaration and now,
after much editing, I find I still need that declaration but can't
remember what it was exactly. Is there a possibility to review the
deleted things by viewing a list or something? Because I know the
keyword of the declaration I could easily recognize and recover it.
Thanks.
Huub
Re: java delete-history recap? [message #115844 is a reply to message #115818] Wed, 09 November 2005 12:22 Go to previous messageGo to next message
Originally posted by: cneff.at.crosslogic.dot.com
Huub -
You can compare your file to the local history. This will show you ALL
the changes you have made, but the deletion should show up pretty well.
-- Clayton --
Re: java delete-history recap? [message #115856 is a reply to message #115844] Wed, 09 November 2005 12:41 Go to previous messageGo to next message
> -- Clayton --
Sorry for asking, but do you mean the "Run history" option?
Re: java delete-history recap? [message #115868 is a reply to message #115856] Wed, 09 November 2005 13:08 Go to previous messageGo to next message
Huub -
No. Right click on the file you want to recover the work for. Select
"Compare With"->"Local History..." and go back as far as you need to
find the line you deleted.
-- Clayton --
Re: java delete-history recap? [message #115881 is a reply to message #115868] Wed, 09 November 2005 13:38 Go to previous message
> -- Clayton --
This is a great. Problem in solved 10 seconds. Thanks.
Previous Topic:How to see complete classname in Problems view with Eclipse3.1
Next Topic:J2EE 1st installation & EJB tutorial
Current Time: Tue Jul 22 09:04:15 EDT 2025
Powered by FUDForum. Page generated in 0.08945 seconds
