Wrong position of combo's dropdown on ScrolledForm [message #115799] |
Mon, 15 December 2008 12:12  |
Hi all,
Here's another snippet to reproduce the problem:
public class ComboDemoEntryPoint implements IEntryPoint
public int createUI()
Display display = new Display();
Shell shell = new Shell(display,SWT.SHELL_TRIM);
shell.setLayout(GridLayoutFactory.swtDefaults().create());
FormToolkit toolkit = new FormToolkit(display);
ScrolledForm container = toolkit.createScrolledForm(shell);
container.setLayoutData(GridDataFactory.fillDefaults().grab( true,
true).create());
container.getBody().setLayout(GridLayoutFactory.fillDefaults ().create());
ComboViewer comboViewer = new
ComboViewer(container.getBody(),SWT.READ_ONLY);
comboViewer.getCombo().setLayoutData(GridDataFactory.fillDef aults().grab(true,
false).create());
comboViewer.add(new String[]{"Item 1","Item 2"});
comboViewer = new ComboViewer(container.getBody(),SWT.READ_ONLY);
false).create());
comboViewer.add(new String[]{"Item 3","Item 4"});
false).create());
comboViewer.add(new String[]{"Item 5","Item 6"});
false).create());
comboViewer.add(new String[]{"Item 7","Item 8"});
false).create());
comboViewer.add(new String[]{"Item 9","Item 10"});
shell.setSize(150,150);
shell.open();
while (!shell.isDisposed())
if (!display.readAndDispatch())
display.sleep();
return 0;
Upon running, scroll to the last combo then click to show its dropdown,
you can see the position is not right.
Setya
Re: Wrong position of combo's dropdown on ScrolledForm [message #116007 is a reply to message #115917] |
Wed, 17 December 2008 04:35   |
Hi Setya,
even your latest snippet looks fine here.
Ralf
Setya wrote:
> I can confirm that the problem no longer exists using latest source from
> CVS and from my previous snippet.
> But I still can reproduce it with the following snippet & latest source
> from CVS:
> @Override
> true).create());
> for (int i = 0; i <= 25; i++)
> false).create());
> shell.setMaximized(true);
> shell.open();
> display.sleep();
> return 0;
> This time don't bother scrolling, just go to the last combo and click to
> dropdown.
> Setya
FUDForum. Page generated in 0.06643 seconds
