Home » Eclipse Projects » Equinox » Software Update
Software Update [message #115735] Wed, 06 August 2008 08:11 Go to next message
I use Eclipse 3.4, and when I create my RCP, I don't get the same software
management of Eclipse 3.4. I always have the old "Sofware Updates" menu
with "Find and install" and "Manage configuration..." subItems. How can I
get the new management? May I use a extension point?
Thanks for your help,
David.
Re: Software Update [message #116066 is a reply to message #115735] Thu, 14 August 2008 17:41 Go to previous messageGo to next message
Originally posted by: eclipseng.arthorne.com
> software management of Eclipse 3.4. I always have the old "Sofware
> Updates" menu with "Find and install" and "Manage configuration..."
> subItems. How can I get the new management? May I use a extension point?
This is because your application is still configured to use the classic
update manager instead of the new p2 system (as defined in config.ini
file). See this document for getting started with using the new
"Software Update" mechanism (aka p2):
http://wiki.eclipse.org/Equinox_p2_Getting_Started_for_Relen g
Re: Software Update [message #119284 is a reply to message #115735] Fri, 10 October 2008 13:06 Go to previous message
I would suggest checking that you've added the correct
org.eclipse.equinox.p2.ui* to be deployed with your RCP app. I think one
of the plugins listed below contributes the ui you are looking for. Also,
you may want to remove org.eclipse.update* plugins.
org.eclipse.equinox.p2.ui.admin.rcp_1.0.0.v20080604.jar
org.eclipse.equinox.p2.ui.admin_1.0.0.v20080522-1735.jar
org.eclipse.equinox.p2.ui.sdk_1.0.1.R34x_v20080818.jar
org.eclipse.equinox.p2.ui_1.0.1.R34x_v20080909.jar
Hope this helps.
Previous Topic:Equinox and RCP trainings
Next Topic:disable default start of Jetty
Current Time: Wed Jun 18 10:40:17 EDT 2025
Powered by FUDForum. Page generated in 0.06906 seconds
