Home » Eclipse Projects » GEF » wizard
wizard [message #115717] Wed, 04 February 2004 18:18 Go to next message
Originally posted by: david_michonneau.hotmail.com
I have a question regarding commands and UI changes.
I'm going to take an example, rather than staying on an abstract level:
Let's say that when I add an element to a graphical editor, a small popup
wizard appears. In each step of the wizardI configure the new object to be
added to the graph. When the wizard is completed the object is created to
the diagram, and this is a single undoable operation.
Now from an implementation point of view, each step in the wizard will be
mapped to a command. Since each step is dependent from the previous one, I
want to be able to execute each command on the model, as the user goes
through each step, so that I know what UI to show in the next step, by
inspecting the model.
How do I do such thing? When I execute a command it goes on the
commandstack. Note that between each commands I've got some different UI to
show, but in the end I want only one big command in the commandstack (that
does not capture the UI, since it's not model related).
David
Re: wizard [message #115743 is a reply to message #115717] Wed, 04 February 2004 18:52 Go to previous messageGo to next message
Originally posted by: Lamont_Gilbert.rigidsoftware.com
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
UI to
| Thanks,
| David
I was not able to affect multi-step commands. I redid my thinking and
baked it all into 1 single command. Perhaps you need to open a
"simulation" window to allow these intermediate steps, and once
confirmed, execute the full command. But that too would be composed of
steps...
I know you pain. The problem is that the results of one command are not
seen by another so to speak.
Like I said, I ended up conflating it into a single command.
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber." John 10:1
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFAIYXJVbJM14DSCi0RAlkIAJ9h5VxHatkHBNgtlB/58nlJJbpp5ACe JpK2
G8LowG5vT+RwCA5IoMPh+mg=
=4fP2
-----END PGP SIGNATURE-----
Re: wizard [message #115756 is a reply to message #115743] Wed, 04 February 2004 19:01 Go to previous messageGo to next message
There is no doubt at the end one single command will be added to the command
stack, the whole problem is the creation of that compoudcommand. For
example:
Command1 -> Model1
if (Model1.condition)
Command2
else
Command3
If I don't execute Command1, I have to mentally compute its result to write
the proper condition. So it;s much more productive to execute commands one
by one. With a large number of commands it can become a real headache. If my
understanding is correct EMF has solved this with
CompoundCommand.appendAndExecute( see my previous post). Now I'm more
interested on how to mix UI actions in between commands.
David
"CL [dnoyeb] Gilbert" <Lamont_Gilbert@rigidsoftware.com> wrote in message
news:bvs0fo$vcj$1@eclipse.org...
> Hash: SHA1
popup
be
to
be
I
> UI to
(that
> | Thanks,
> | David
> steps...
> Respectfully,
> CL Gilbert
> =4fP2
Re: wizard [message #115807 is a reply to message #115717] Thu, 05 February 2004 00:25 Go to previous messageGo to next message
> will be mapped to a command. Since each step is dependent from the
> previous one, I want to be able to execute each command on the model,
> as the user goes through each step, so that I know what UI to show in
> the next step, by inspecting the model.
Using this approach you have to take care that you model is not in an
inconsistent state when the user clicks "Cancel" (remember, a wizard should
be cancelable).
> commandstack.
When you execute a command, it will be executed.
> UI to show, but in the end I want only one big command in the
> commandstack (that does not capture the UI, since it's not model
> related).
So you want a CompoundCommand.
I don't know you model but have you ever looked at the Eclipse wizard
framework? A wizards consists of several pages and they are not operating on
the model directly until the user has clicked "Finish". I would suggest
going this way. Get some working copies of your model elements and mangle
these (do with them whatever you like). It is even possible to execute the
commands on these elements without going through the editor. Simply call the
command yourself. If the user clicks "Finish" you are free to create a
CompoundCommand and throw it to an execution engine (which could be but is
not limited to your editor). Going this way might give you a chance to reuse
the wizards outside of your editors.
Cu, Gunnar
Re: wizard [message #115998 is a reply to message #115756] Thu, 05 February 2004 13:50 Go to previous messageGo to next message
Originally posted by: phil.williams.toadmail.com
--------------060600020904020402030606
Content-Type: text/plain; charset=us-ascii; format=flowed
One approach that I can think of is to do something similar to how
connections are added in the Logic Example. Take a look at the
LogicNodeEditPolicy.
When you mouse over and click on a source getConnectionCreateCommand is
called. Notice that the command (which is incomplete) is added to the
request. When the user clicks on the target node, the command is
retrieved off of the request and the missing parts (the target) are
added. After the command is returned the exec method is called.
So what I think you would have is a single command class to which each
page of the wizard adds pieces. Then at the end of the wizard the exec
method on the command is called and it is added to the command stack. I
guess that the main wizard will most likely have a handle to the command
and the appropriate getters and setters.
HTH,
Phil
>example:
>Command1 -> Model1
> Command2
>else
> Command3
>David
>>Hash: SHA1
>popup
>be
>to
>be
>I
>>UI to
>(that
>>| Thanks,
>>| David
>>steps...
>>Respectfully,
>>CL Gilbert
>>=4fP2
Content-Type: text/html; charset=us-ascii
<html>
<head>
<title></title>
</head>
<body>
connections are added in the Logic Example.&nbsp; Take a look at the
LogicNodeEditPolicy.<br>
<br>
called.&nbsp; Notice that the command (which is incomplete) is added to the
request.&nbsp; When the user clicks on the target node, the command is
added.&nbsp; After the command is returned the exec method is called.<br>
<br>
page of the wizard adds pieces.&nbsp; Then at the end of the wizard the exec
method on the command is called and it is added to the command stack.&nbsp;
I guess that the main wizard will most likely have a handle to the
command and the appropriate getters and setters.<br>
<br>
HTH,<br>
Phil<br>
<br>
<br>
David Michonneau wrote:<br>
<blockquote cite="midbvs10q$vsl$1@eclipse.org" type="cite">
<pre wrap="">There is no doubt at the end one single command will be added to the command
example:
Command1 -&gt; Model1
Command2
else
Command3
David
"CL [dnoyeb] Gilbert" <a class="moz-txt-link-rfc2396E" href="mailto:Lamont_Gilbert@rigidsoftware.com">&lt;Lamont_Gilbert@rigidsoftware.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:bvs0fo$vcj$1@eclipse.org">news:bvs0fo$vcj$1@eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
</pre>
</blockquote>
<pre wrap=""><!---->popup
</pre>
<pre wrap="">| wizard appears. In each step of the wizardI configure the new object to
</pre>
</blockquote>
<pre wrap=""><!---->be
</pre>
<pre wrap="">| added to the graph. When the wizard is completed the object is created
</pre>
</blockquote>
<pre wrap=""><!---->to
</pre>
<pre wrap="">| the diagram, and this is a single undoable operation.
</pre>
</blockquote>
</pre>
<pre wrap="">| mapped to a command. Since each step is dependent from the previous one,
</pre>
</blockquote>
<pre wrap=""><!---->I
</pre>
<pre wrap="">| want to be able to execute each command on the model, as the user goes
UI to
</pre>
</blockquote>
<pre wrap=""><!---->(that
</pre>
<pre wrap="">| does not capture the UI, since it's not model related).
| Thanks,
| David
steps...
Respectfully,
CL Gilbert
<a class="moz-txt-link-freetext" href="http://www.rigidsoftware.com/Chess/chess.html">http://www.rigidsoftware.com/Chess/chess.html</a>
Comment: Using GnuPG with Mozilla - <a class="moz-txt-link-freetext" href="http://enigmail.mozdev.org">http://enigmail.mozdev.org</a>
=4fP2
</pre>
</blockquote>
</pre>
</blockquote>
</body>
</html>
--------------060600020904020402030606--
Re: wizard [message #117098 is a reply to message #115717] Wed, 11 February 2004 15:14 Go to previous message
I'm not sure why you are reusing the command classes in this way. Other
teams I know have created the notion of an Operation, and some sort of model
behind an operation which the dialog knows how to populate. At the end when
Finish is pressed, the operation constructs a single command.
But, if you really want to reuse the command pattern, you could comment out
execute() to do nothing, and perform the execution as you go calling your
own myExecute() API. Then, wrap it all up in a compound command and slap it
on the command stack, at which point it will be executed but that will be a
no-op at this point. Only undo() and redo() would be functional.
"David Michonneau" <david_michonneau@hotmail.com> wrote in message
news:bvruf9$tfc$1@eclipse.org...
to
> David
Previous Topic:creating connections
Next Topic:I20040205 + M6 -> 100% cpu usage on gtk
Current Time: Sat Jun 21 20:42:23 EDT 2025
Powered by FUDForum. Page generated in 0.26198 seconds
