Home » Eclipse Projects » Equinox » patch behavior
patch behavior [message #115669] Tue, 05 August 2008 11:26 Go to next message
Hi All,
Are patches supposed to work as in the Europa version? I have a
feature x(the only one that appears in InstalledSoftwares panel) and i
have a repo that contains feature y that is a patch for feature x. Since i
add this feature y repository, should not the patch be presented when i
try updating feature X?
i will be very thankful for any information about that.
Gladyston
Re: patch behavior [message #115931 is a reply to message #115669] Tue, 12 August 2008 12:21 Go to previous messageGo to next message
Originally posted by: eclipseng.arthorne.com
Patch features are supported in the Ganymede version. However, updating
a feature should not cause patches to be installed as far as I know. The
patch should be available for install from the available software tab.
Gladyston wrote:
> Hi All,
> i add this feature y repository, should not the patch be presented when
> i try updating feature X?
> Gladyston
Re: patch behavior [message #115980 is a reply to message #115931] Wed, 13 August 2008 09:50 Go to previous message
John,
it was what i suspected. i really want a confirmation, thanks a lot.
P.S. my project needs sign all jars that goes in the product, i am
currently signing those jars in a script made by hand (not PDE build). It
was because inspecting PDE code i realized that it does not handle key
passwords, just keystore passwords. Am I able to contribute code fixing
this issue, if so, where am i suppose to post it.
Gladyston
Previous Topic:Orbit packages with versions
Next Topic:How to shutdown OSGi?
Current Time: Fri Nov 07 04:21:32 EST 2025
Powered by FUDForum. Page generated in 0.06125 seconds
