Home » Eclipse Projects » GEF » emf/gef commands
emf/gef commands [message #115456] Tue, 03 February 2004 13:12 Go to next message
Originally posted by: david_michonneau.hotmail.com
I am trying to build a GEF editor, with an EMF model. Since I also have some
JFace editors, I would like to use the EMF.Edit generated classes. The issue
is that the GEF commands and EMF commands belong to different packages,
although they have a very similar interface.
I know that Jeez implemented a solution with wrapper classes to mix GEF and
EMF commands, but I am not totally convinced by this.
So my question is: is it possible to use EMF.Edit, and override all the
generated commands (and basic commands) to produce my own GEF commands
instead? If yes, how to override them?
David
Re: emf/gef commands [message #117225 is a reply to message #115456] Wed, 11 February 2004 20:46 Go to previous message
David,
I don't think you can do it by overriding the generated EMF commands since
the GEF framework expects the GEF commands to inherit from
org.eclipse.gef.commands.Command. There is no GEF command interface you can
make subclasses of the EMF commands implement. I got GEF and EMF commands
working together by having my GEF commands delegate to EMF commands. My GEF
editor only ever deals with GEF commands (which happen to use EMF commands
to get the job done), so in effect I am wrappering, but not in the same way
as the Jeez implementation (I think). Make sense?
Sean.
"David Michonneau" <david_michonneau@hotmail.com> wrote in message
news:bvoo5s$bdt$1@eclipse.org...
some
issue
and
> David
Previous Topic:NoClassDefFoundError
Next Topic:GEF or SWT-Designer (newbie question)
Current Time: Sat Jul 26 10:19:34 EDT 2025
Powered by FUDForum. Page generated in 0.09708 seconds
