Home » Archived » Visual Editor (VE) » how to shut off the reverse-parser?
how to shut off the reverse-parser? [message #115320] Mon, 16 January 2006 05:44 Go to next message
Originally posted by: dbhomers.becker-print-soft.com
How can i shut off the Update-Process of the VE?
If i must change a lot, this process slow down my work cause it updates
after every char i changed.
thanks for helping!
Re: how to shut off the reverse-parser? [message #115350 is a reply to message #115320] Mon, 16 January 2006 09:15 Go to previous message
Dirk,
There's a pause button on the toolbar - it looks like two yellow
vertical rectangles, and has the tooltip that says "Pause". This halts
the reverse parser so that you can make significant changes to the
source. When you're done making changes click the button again to have
the visual model sync up with the source again.
Hope this helps,
- Jeff
Re: how to shut off the reverse-parser? [message #611787 is a reply to message #115320] Mon, 16 January 2006 09:15 Go to previous message
Dirk,
Hope this helps,
- Jeff
Previous Topic:Why am not able to see my customlayout in the properties list???
Next Topic:How begins
Current Time: Thu Nov 06 18:53:46 EST 2025
Powered by FUDForum. Page generated in 0.03848 seconds
