| "Device is disposed".. Where could I ask help [message #115178] |
Fri, 22 August 2003 18:04  |
Originally posted by: andreas.moroder.gmx.net
I am new to eclipse and I get a "Device is disposed" error in the .log.
Because I could not find a newgroup or mailing list for simple users, I
ask here.
Could you give me a hint where to aks or how to resolve the problem ?
My system is
Suse Linux 8.1
java2 ( jre 1.3.1)
ant 1.5
latest eclipse
Thank you
Andreas
| Re: "Device is disposed".. Where could I ask help [message #117570 is a reply to message #116571] |
Wed, 27 August 2003 15:32  |
Simon Arsenault wrote:
> I've asked someone from the SWT team to take a look at this.
> Could you attach the complete .log file (assuming it is not too big...if it
> is, rename it, and try to reproduce the problem then attach the .log file).
> Simon :-)
> "Andreas Moroder" <andreas.moroder@gmx.net> wrote in message
> news:bidj0b$7pn$1@eclipse.org...
> > Hello Simon,
> > here my .log file
> > !SESSION
> > !ENTRY org.eclipse.core.launcher 4 0 Aug 22, 2003 23:24:58.927
> > !MESSAGE Exception launching the Eclipse Platform:
> > !STACK
> > java.lang.reflect.InvocationTargetException:
> > java.lang.reflect.InvocationTargetException: org.eclipse.swt.SWTException:
> > Device is disposed
> > at org.eclipse.swt.SWT.error(SWT.java:2332)
> > at org.eclipse.swt.SWT.error(SWT.java:2262)
> > at org.eclipse.swt.widgets.Display.createDisplay(Display.java:4 84)
> > at org.eclipse.swt.widgets.Display.create(Display.java:469)
> > at org.eclipse.swt.graphics.Device.<init>(Device.java:111)
> > at org.eclipse.swt.widgets.Display.<init>(Display.java:303)
> > at org.eclipse.swt.widgets.Display.<init>(Display.java:299)
> > at org.eclipse.ui.internal.Workbench.run(Workbench.java:1361)
> > at
> org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
> a:858)
> > at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
> > at java.lang.reflect.Method.invoke(Native Method)
> > at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
> > at org.eclipse.core.launcher.Main.run(Main.java:747)
> > at org.eclipse.core.launcher.Main.main(Main.java:583)
> > I hope this could help to find the reason for the Exception
> > Thanks
> > Andreas
> > > Is there a stack trace also in the .log file?
> > > Simon :-)
> > > "Andreas" <andreas.moroder@gmx.net> wrote in message
> > > news:3F469350.5040904@gmx.net...
> > > > Hello,
> ..log.
> I
> > > > ask here.
> > > > My system is
> > > > Suse Linux 8.1
> > > > java2 ( jre 1.3.1)
> > > > ant 1.5
> > > > latest eclipse
> > > > Thank you
> > > > Andreas
Hello Simon,
that was the entire log file. Maybe there is a parameter to tell eclipse
to be more verbose, but I am new, so I don't know it.
Andreas
FUDForum. Page generated in 0.07066 seconds
