Home » Eclipse Projects » Eclipse Platform » PDE build of non-library jar (like the way org.eclipse.pde.build project builds its ant lib)
| PDE build of non-library jar (like the way org.eclipse.pde.build project builds its ant lib) [message #115112] |
Fri, 22 August 2003 15:45  |
Originally posted by: richkulp.NOSPAM.us.ibm.com
I have a jar that needs to be built in a project, but is not a plugin
library. The project is a plugin project. I tried to do like the
org.eclipse.pde.build project does with the lib/pdebuild-ant.jar.
What is done there is the build.properties file has:
source.pdebuild.jar=src/
source.lib/pdebuild-ant.jar=src_ant/
jars.compile.order=pdebuild.jar,lib/pdebuild-ant.jar
jars.extra.classpath=../org.apache.ant/ant.jar
bin.includes=plugin.xml,plugin.properties,about.html,*.jar,l ib/*.jar,scripts/,
templates/, feature/, notes/
src.includes=about.html
So there is a source.lib/pdebuild-ant.jar=src_ant/ entry to tell where
the pdebuild-ant.jar source is at. But there is no library stmt for it
in the plugin.xml. I tried to do this, but whenever I change the
plugin.xml it removes from the classpath that jar's source directory.
How does pdebuild do this so that it is isn't wiped out each time? Or do
they take that as a consequence and simply put it back each time?
Thanks, Rich Kulp
| Re: PDE build of non-library jar (like the way org.eclipse.pde.build project builds its ant lib) [message #115951 is a reply to message #115112] |
Mon, 25 August 2003 09:15   |
------=_NextPart_000_000C_01C36AE9.7D3E1250
Content-Type: text/plain;
charset="iso-8859-1"
Since 3.0M2 the builder supports new options allowing the specification =
of classpath on a library basis.
For example, the build.properties previously given becomes:
source.pdebuild.jar=3Dsrc/
source.lib/pdebuild-ant.jar=3Dsrc_ant/
jars.compile.order=3Dpdebuild.jar,lib/pdebuild-ant.jar
extra.lib/pdebuild-ant.jar=3D../org.apache.ant/ant.jar
bin.includes=3Dplugin.xml,plugin.properties,about.html,*.jar ,lib/*.jar,sc=
ripts/, templates/, feature/, notes/
src.includes=3Dabout.html
HTH
PaScaL
"Richard L. Kulp" <richkulp@NOSPAM.us.ibm.com> wrote in message =
news:bi5roi$ub3$1@eclipse.org...
> I have a jar that needs to be built in a project, but is not a plugin=20
> library. The project is a plugin project. I tried to do like the=20
>=20
>=20
> jars.extra.classpath=3D../org.apache.ant/ant.jar
ripts/,=20
>=20
> So there is a source.lib/pdebuild-ant.jar=3Dsrc_ant/ entry to tell =
where=20
> the pdebuild-ant.jar source is at. But there is no library stmt for it =
> in the plugin.xml. I tried to do this, but whenever I change the=20
>=20
> How does pdebuild do this so that it is isn't wiped out each time? Or =
do=20
>=20
> --=20
> Thanks, Rich Kulp
> =1A
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1141" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Since 3.0M2 the builder supports new =
options=20
allowing the specification of classpath on a library basis.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>For example, the build.properties =
previously given=20
becomes:</FONT></DIV>
<DIV>
<P><FONT face=3DArial =
size=3D2>source.pdebuild.jar=3Dsrc/<BR></FONT><FONT face=3DArial=20
size=3D2>source.lib/pdebuild-ant.jar=3Dsrc_ant/<BR></FONT ><FONT =
face=3DArial=20
size=3D2>jars.compile.order=3Dpdebuild.jar,lib/pdebuild-ant.jar <BR></FONT=
><FONT=20
face=3DArial=20
size=3D2>extra.lib/pdebuild-ant.jar=3D../org.apache.ant/ant.jar <BR></FONT=
><FONT=20
face=3DArial=20
size=3D2> bin.includes=3Dplugin.xml,plugin.properties,about.html,*.jar ,lib=
/*.jar,scripts/,=20
templates/, feature/, notes/<BR></FONT><FONT face=3DArial=20
size=3D2>src.includes=3Dabout.html</FONT></P>
<P><FONT face=3DArial size=3D2>HTH</FONT></P>
<P><FONT face=3DArial size=3D2> PaScaL</FONT></P></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>"Richard L. Kulp" <</FONT><A=20
href=3D"mailto:richkulp@NOSPAM.us.ibm.com"><FONT face=3DArial=20
size=3D2>richkulp@NOSPAM.us.ibm.com</FONT></A><FONT face=3DArial =
size=3D2>> wrote=20
in message </FONT><A href=3D"news:bi5roi$ub3$1@eclipse.org"><FONT =
face=3DArial=20
size=3D2>news:bi5roi$ub3$1@eclipse.org</FONT></A><FONT face=3DArial=20
size=3D2>...</FONT></DIV><FONT face=3DArial size=3D2>> I have a jar =
that needs to=20
be built in a project, but is not a plugin <BR>> library. The project =
is a=20
plugin project. I tried to do like the <BR>> org.eclipse.pde.build =
project=20
does with the lib/pdebuild-ant.jar.<BR>> <BR>> What is done there =
is the=20
build.properties file has:<BR>> <BR>> =
source.pdebuild.jar=3Dsrc/<BR>>=20
source.lib/pdebuild-ant.jar=3Dsrc_ant/<BR>>=20
jars.compile.order=3Dpdebuild.jar,lib/pdebuild-ant.jar<BR>>=20
jars.extra.classpath=3D../org.apache.ant/ant.jar<BR>>=20
ripts/,=20
<BR>> templates/, feature/, notes/<BR>> =
src.includes=3Dabout.html<BR>>=20
<BR>> So there is a source.lib/pdebuild-ant.jar=3Dsrc_ant/ entry to =
tell where=20
<BR>> the pdebuild-ant.jar source is at. But there is no library stmt =
for it=20
<BR>> in the plugin.xml. I tried to do this, but whenever I change =
the=20
<BR>> plugin.xml it removes from the classpath that jar's source=20
directory.<BR>> <BR>> How does pdebuild do this so that it is =
isn't wiped=20
out each time? Or do <BR>> they take that as a consequence and simply =
put it=20
back each time?<BR>> <BR>> -- <BR>> Thanks, Rich Kulp<BR>> =
=1A<BR>>=20
</FONT></BODY></HTML>
------=_NextPart_000_000C_01C36AE9.7D3E1250--
| Re: PDE build of non-library jar (like the way org.eclipse.pde.build project builds its ant lib) [message #116556 is a reply to message #116427] |
Tue, 26 August 2003 10:08  |
The problem is this: Take the following build.properties:
extra.lib/pdebuild-ant.jar=../org.apache.ant/ant.jar
The jar, lib/pdebuild-ant.jar, is not a plugin library. I.E. there is no
<library> element for it in the plugin.xml. However, it is a jar that is
built in this plugin to be used by any ANT process when ANT is started.
It will get added to the ANT's classloader. Because it is a jar compiled
in this project, the .classpath has a source folder entry pointing to
src_ant/ folder. So it gets compiled just like the <library> jar
pdebuild.jar.
The problem is in 2.1.1 is that if you now go to the plugin.xml file and
update it for some reason, it recreates the .classpath file and wipes
out the source entry for src_ant folder. Now it no longer compiles
within Eclipse. It no longer shows up as code that you can edit and do
java searches on. This is because the PDE will only put in the
..classpath source folders for jars that are listed in BOTH the
build.properties and the plugin.xml <library> stmts. This makes it very
difficult to build non-<library> jars in a plugin using PDE.
I have three or four plugins that have this condition. We are running
jars outside of Eclipse. If we use this pattern, which is the pattern
that PDE is using to build their ant.jar, we have to be very careful
every time we update the plugin.xml. We will need to remember to go back
and update the classpath separately to put the non-library jar back in
the compile path.
On a side note, I don't really like the idea of building (both in
Eclipse and through the build.xml) a non-library jar in a plugin
project. I prefer having the non-library jar being built separately in a
non-plugin project and then being pulled into the plugin project by the
build. But I don't want to write a custom build.xml for this because
then when anything changes in the plugin.xml that requires a new
build.xml I need recreate it and put the code back in again. A build.xml
produced by PDE is actually very complicated and I don't want to have to
delve into it each time a change is needed. It would be nice if the PDE
had a concept of non-library jars in other projects and built and pulled
them in automatically. This way the classpaths can be totally separated.
Both for the Eclipse JDT compiles and the PDE build.xml compiles.
Rich
Current Time: Sat Nov 08 21:14:45 EST 2025
Powered by FUDForum. Page generated in 0.37357 seconds
