Home » Language IDEs » ServerTools (WTP) » XML source editor missing?!
XML source editor missing?! [message #115040] Fri, 01 July 2005 05:31 Go to next message
I just downloaded and installed WTP M5 (with all the required plugins).
May be I'm just blind, but I can't find the XML source editor.
In Prefrences->General->Editors->File Associations if you push
the "Add" button for an arbitrary file extension there's no
XML source editor available in the Editor Selection dialog.
Can someone point me in the right direction, please?
Thanks!
Christian
Re: XML source editor missing?! [message #115128 is a reply to message #115040] Fri, 01 July 2005 10:29 Go to previous messageGo to next message
Christian Schmitt wrote:
> Thanks!
> Cheers,
> Christian
Christian,
No, you're not blind. You probably had selected a type that already had
the XML Editor associated with it. Try creating a new type, e.g. *.zml
and then associate the XML Editor with it. BTW - there is now only the
unified XML Editor (no more Source only variant).
-- Arthur
Re: XML source editor missing?! [message #115168 is a reply to message #115128] Fri, 01 July 2005 10:58 Go to previous messageGo to next message
Arthur Ryman wrote:
> Christian,
> -- Arthur
Arthur,
thanks for the info. I can open the files in the XML editor, but it's the
structured tree-like editor. I'd rather edit the text like in the Ant
editor or the plugin.xml editor (plugin.xml tab).
Is there a setting somewhere that let's me choose whether to open in the
(now?) default mode or the (not there anymore?) XML Source mode?
Thanks for your time.
Christian
Re: XML source editor missing?! [message #115180 is a reply to message #115168] Fri, 01 July 2005 11:00 Go to previous message
Artur,
ignore my last post. I just saw the "Design" and "Source" tabs at the
bottom of the editor window. I must be blind after all!
Christian
Previous Topic:How do I configure an existing web module in Eclipse 3.1 + Web Tools M5 ?
Next Topic:WS authentication
Current Time: Fri Jul 18 06:00:12 EDT 2025
Powered by FUDForum. Page generated in 0.04942 seconds
