Home » Eclipse Projects » Eclipse Platform » Ant plugin update to v1.5.4?
Ant plugin update to v1.5.4? [message #115007] Fri, 22 August 2003 14:33 Go to next message
Originally posted by: erstwhileiii.netscape.net
I have searched for a mechanism to update the Ant plugin in eclipse from
v1.5.3 to v1.5.4 (released earlier this month) ... but have not found any
information. I suspect that the process is more involved than simply
updating the ant.jar and optional.jar in the plugin directory. I have
searched both the eclipse and the apache site for this information.
Did I miss the information somewhere ... or has the upgraded plugin not been
made available yet?
Joseph
Re: Ant plugin update to v1.5.4? [message #115048 is a reply to message #115007] Fri, 22 August 2003 15:32 Go to previous messageGo to next message
The upgraded plugin is available as of the Integration build that came out
earlier this week.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=41277
The process is not really any more involved than updating the ant.jar and
the optional.jar.
Of course you can set Eclipse's Ant integration to use any Ant install by
setting the correct ANT_HOME either globally using the Ant runtime classpath
preference page or for any specific Ant launch configuration on the
classpath tab.
I mostly work on Ant 1.6.
OT: Any particular reason you are moving to Ant 1.5.4...it has a pretty
minor set of bug fixes.
HTH
Darins
"Joseph White" <erstwhileiii@netscape.net> wrote in message
news:bi5nld$pf2$1@eclipse.org...
been
> made available yet?
> Joseph
Re: Ant plugin update to v1.5.4? [message #117047 is a reply to message #115048] Tue, 26 August 2003 23:26 Go to previous message
Thanks. Perhaps I should look at Ant 1.6 also.
Joe
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:bi5r2h$tiu$1@eclipse.org...
> earlier this week.
> the optional.jar.
classpath
> classpath tab.
> HTH
> Darins
any
> been
> > made available yet?
> > Regards,
> > Joseph
Previous Topic:Examples cause large pauses/cpu utilization in 3.0 stream
Next Topic:local history
Current Time: Tue Jul 15 14:17:07 EDT 2025
Powered by FUDForum. Page generated in 0.27255 seconds
