Home » Modeling » GMF (Graphical Modeling Framework) » newly generated diagram code fails when trying to create a new diagram
newly generated diagram code fails when trying to create a new diagram [message #114811] Tue, 27 March 2007 18:09 Go to next message
I just re-generated all code using the just downloaded v2.0M5uh (from a
prior v2.0M5).
After regeneration I open the Run-dialog. I first deselect everything,
then I select my project <foo> plus all generated projects, i.e.
<foo>.diagram, <foo>.edit and <foo>.editor and then click "add required
plugins" and finally I run the application.
The runtime workbench comes up as expected. In it I try to create a new
diagram using New => Other... => Examples => <foo> Diagram. I hit "Next"
and I get an error "Problem Opening Wizard: the selected wizard could
not be started". ????!?
There is no entry in the logs, neither in the developing instance's log
nor in the runtime-workbench's log. How do I debug this? How do I find
out, why I now can't create any new diagrams any more???
Michael
Re: newly generated diagram code fails when trying to create a new diagram [message #114882 is a reply to message #114811] Wed, 28 March 2007 04:03 Go to previous messageGo to next message
Originally posted by: fbanica.soluta.net
Was it working first (with GMF 2.0 M5)? If so, try recreating all the
projects into the new GMF 2.0 M5uh (maybe you can use the dashborad to make
it easier/faster)...
Floppy
"Michael Moser" <mmo@zurich.ibm.com> wrote in message
news:euc4lt$51k$1@utils.eclipse.org...
> prior v2.0M5).
> Michael
Re: newly generated diagram code fails when trying to create a new diagram [message #115192 is a reply to message #114882] Wed, 28 March 2007 16:30 Go to previous messageGo to next message
"Florin Banica" <fbanica@soluta.net> wrote in message
news:eud7je$3ej$1@utils.eclipse.org...
yes
> If so, try recreating all the projects into the new GMF 2.0 M5uh
> (maybe you can use the dashborad to make it easier/faster)...
??? that's exactly what I had tried and which caused the described
error.
I have not recreated the .gmf* files (for obvious reasons) but the
..gmfgen and all depending projects (.edit, .editor and .diagram).
Michael
Re: newly generated diagram code fails when trying to create a new diagram [message #115507 is a reply to message #114882] Fri, 30 March 2007 00:18 Go to previous message
Originally posted by: bhatia1984.yahoo.com
hiii
It may be due to different versions of gmf u r using.
Previous Topic:Change xml scema?
Next Topic:Context (right mouse click) menu use / example
Current Time: Tue Nov 04 10:32:01 EST 2025
Powered by FUDForum. Page generated in 0.06954 seconds
