newly generated diagram code fails when trying to create a new diagram [message #114811] |
Tue, 27 March 2007 18:09  |
I just re-generated all code using the just downloaded v2.0M5uh (from a
prior v2.0M5).
After regeneration I open the Run-dialog. I first deselect everything,
then I select my project <foo> plus all generated projects, i.e.
<foo>.diagram, <foo>.edit and <foo>.editor and then click "add required
plugins" and finally I run the application.
The runtime workbench comes up as expected. In it I try to create a new
diagram using New => Other... => Examples => <foo> Diagram. I hit "Next"
and I get an error "Problem Opening Wizard: the selected wizard could
not be started". ????!?
There is no entry in the logs, neither in the developing instance's log
nor in the runtime-workbench's log. How do I debug this? How do I find
out, why I now can't create any new diagrams any more???
Michael
FUDForum. Page generated in 0.04570 seconds
