Home » Eclipse Projects » GEF » editpart.performrequest
editpart.performrequest [message #114801] Thu, 29 January 2004 22:38 Go to next message
Originally posted by: david_michonneau.hotmail.com
What is the typical use of EditPart.PeformRequest function? Is it used to
trigger application level commands (such as opening a dialog box)? Or is it
for something else?
David
Re: editpart.performrequest [message #114929 is a reply to message #114801] Fri, 30 January 2004 11:19 Go to previous messageGo to next message
Yes, that is a good example. It is used for whenever you want to delegate
the implementation of something like that to the editpart. For some apps
this feels "cleaner", for others it is required because editparts may be the
means of extending an editor's capability.
"David Michonneau" <david_michonneau@hotmail.com> wrote in message
news:bvcjeu$9uf$1@eclipse.org...
it
> for something else?
> David
Re: editpart.performrequest [message #115265 is a reply to message #114929] Mon, 02 February 2004 14:35 Go to previous messageGo to next message
Thanks, is there any example of an implementation using performRequest to
trigger an application level command?
David
"Randy Hudson" <none@us.ibm.com> wrote in message
news:bve02a$t1e$1@eclipse.org...
the
> > Hi,
to
> it
> > for something else?
> > Thanks,
> > David
Re: editpart.performrequest [message #115446 is a reply to message #115265] Tue, 03 February 2004 13:05 Go to previous message
Yes, press F2 in the logic example while a "label" is selected, will send a
request to perform direct editing. See DirectEditAction and how it is used
in the Logic Example.
news:bvm8lm$hvn$1@eclipse.org...
> David
delegate
apps
> the
> > > Hi,
> to
is
> > it
> > > for something else?
> > > Thanks,
> > > David
Previous Topic:Ensuring a child fits in the parent figure
Next Topic:3.0M6
Current Time: Sat Nov 08 11:06:39 EST 2025
Powered by FUDForum. Page generated in 0.02638 seconds
