Home » Archived » Visual Editor (VE) » Center JFrame?
Center JFrame? [message #114685] Thu, 05 January 2006 19:25 Go to next message
Originally posted by: david.welford-costelloe.com
Been trying to get this to work as per code below:
No matter what I try I can't get the JFrame to center on the screen.
private void initialize() {
// Configure Platform GUI
SetUpGUIApplication();
this.setJMenuBar(getJJMenuBar());
this.setIconImage(Toolkit.getDefaultToolkit().getImage(getCl ass().getResource( "/resources/FLGCAN.png")));
this.setDefaultCloseOperation(javax.swing.JFrame.EXIT_ON_CLO SE);
this.setResizable(false);
this.setContentPane(getJContentPane());
this.setTitle("My Sample App");
this.setVisible(true);
this.setSize(482, 342);
this.setLocationRelativeTo(null);
private static void SetUpGUIApplication(){
String errMsg = null;
try {
// UIManager.setLookAndFeel(UIManager.getSystemLookAndFeelClass Name());
UIManager.setLookAndFeel(UIManager.getCrossPlatformLookAndFe elClassName());
// javax.swing.SwingUtilities.updateComponentTreeUI(this);
} catch (Exception e) {
errMsg = "Error invoking PlatForm Look and Feel";
JOptionPane.showMessageDialog(null, errMsg + ":\n" + e.getLocalizedMessage());
Any help would be appreciated.
Re: Center JFrame? [message #114709 is a reply to message #114685] Thu, 05 January 2006 19:38 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
No where in this code are you doing a this.setLocation(). Without that
you can't center it. You need to calculate the center of the screen and
then do a setLocation to it.
David Costelloe wrote:
> try {
> Thanks
Rich Kulp
Re: Center JFrame? [message #114721 is a reply to message #114685] Thu, 05 January 2006 19:46 Go to previous messageGo to next message
I use:
To help a little more on run it starts at center then shoots back to the left.
Re: Center JFrame? [message #114734 is a reply to message #114721] Fri, 06 January 2006 03:16 Go to previous messageGo to next message
Yes, setLocationRelativeTo(null) centers the window in the screen. This
works for me.
I observe you call setVisible(true) before setting the window size. I
think this don't will work.
May be interesting you center the window before do a setVisible(true). If
not, the window is showed before be centered and you can see how the
window is centered in the screen.
IMHO I think the initialize method is not a good place for a setVisible
call. If is an application, is better invoke setVisible from the main
method and even the setLocationRelativeTo(null).
Francesc Rosés
Re: Center JFrame? [message #114788 is a reply to message #114734] Fri, 06 January 2006 10:55 Go to previous message
Thanks!
That worked well also I forgot to add the Jframe myframe = new Jframe(); in my main.
I had been running it as a jbean in eclipse which seems to add a launcher. Add the above to main and removed the set visible.
One of my co-workers pointed this out :-(
frmMain myMain = null;
myMain = new frmMain();
myMain.setVisible(true);
* This is the default constructor
public frmMain() {
super();
initialize();
I had left it blank as I thought Eclipse had generated the code using the JFrame template.
Appreciate the help thanks
Re: Center JFrame? [message #611740 is a reply to message #114685] Thu, 05 January 2006 19:38 Go to previous message
> try {
> Thanks
Rich Kulp
Re: Center JFrame? [message #611741 is a reply to message #114685] Thu, 05 January 2006 19:46 Go to previous message
I use:
Re: Center JFrame? [message #611742 is a reply to message #114721] Fri, 06 January 2006 03:16 Go to previous message
works for me.
Francesc Rosés
Re: Center JFrame? [message #611746 is a reply to message #114734] Fri, 06 January 2006 10:55 Go to previous message
Thanks!
public frmMain() {
super();
initialize();
Previous Topic:VE 1.2M1 : how to set input for TableViewer
Next Topic:Error trying to set new file into editor
Current Time: Wed Oct 29 08:59:17 EDT 2025
Powered by FUDForum. Page generated in 0.04856 seconds
