Home » Archived » Visual Editor (VE) » SWT layout different on Win XP and Mac OS X
SWT layout different on Win XP and Mac OS X [message #114619] Thu, 05 January 2006 18:46 Go to next message
Please refer to the pictures attached pc.png and mac.png for easy
understanding.
http://www.medclipse.ch/newsgrpeclipse/mac.png
http://www.medclipse.ch/newsgrpeclipse/pc.png
I built some interface with VE. If I open the file in windows xp or in
mac os X, the layout is not the same. See the length between the last
tab and the border in the pictures attached.
Should I open a bug for that ? If yes, where in swt or ve ?
The problem persists after packaging the application for each plateform
Dominique
P:S: I am using Mac OS X 10.4 Java 1.5 Eclipse 3.2M4 VE1.2M1
Re: SWT layout different on Win XP and Mac OS X [message #114648 is a reply to message #114619] Thu, 05 January 2006 19:10 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
This is probably not a bug at all. From looking at the images I'm
guessing that the preferred sizes of the controls are just different
between OSX and Windows. They are being layed out correctly due to
different preferred widths. Each system can decide what the preferred
widths are for a control.
The reason I believe it is ok is bacause look at the "Facturer" button
above the tabs. It is also brought in which means that the desired size
of the window is smaller.
The way you can tell if it is the VE or not is to just run the actual
class outside of VE on the two systems and compare them. If different
then it is not the VE.
Dominique Buenzli wrote:
> Hello,
> understanding.
> Thanks
> Dominique
Rich Kulp
Re: SWT layout different on Win XP and Mac OS X [message #114659 is a reply to message #114619] Thu, 05 January 2006 19:16 Go to previous message
Hi Dominique,
VE just reflects UI as if it were run. You would have the same
difference if you ran the file as an application. Unfortunately native
widgets differ a lot in appearance, and MAC tabs (and some components)
seem to have more padding by default than windows, and hence the
difference in layout. You could ask the SWT newsgroup about it, but it
looks like just differences in the native widgets itself.
Sri.
> Hello,
> understanding.
> Thanks
> Dominique
Re: SWT layout different on Win XP and Mac OS X [message #611735 is a reply to message #114619] Thu, 05 January 2006 19:10 Go to previous message
> Hello,
> understanding.
> Thanks
> Dominique
Rich Kulp
Re: SWT layout different on Win XP and Mac OS X [message #611736 is a reply to message #114619] Thu, 05 January 2006 19:16 Go to previous message
Hi Dominique,
Sri.
> Hello,
> understanding.
> Thanks
> Dominique
Previous Topic:SWT layout different on Win XP and Mac OS X
Next Topic:Center JFrame?
Current Time: Sun Jul 27 07:20:25 EDT 2025
Powered by FUDForum. Page generated in 0.04017 seconds
