Home » Archived » BIRT » BIRT and ORM
BIRT and ORM [message #121] Tue, 02 November 2004 03:18 Go to next message
Originally posted by: djb.dolbyX.com
Will BIRT be able to consume popular ORM tools such as Hibernate and
JDO? This would enable us to leverage our existing data sources without
recoding.
Thanks.
Darren Bell
Senior Software Engineer
Dolby Laboratories Inc.
Re: BIRT and ORM [message #124 is a reply to message #121] Mon, 08 November 2004 07:10 Go to previous messageGo to next message
we should use both:
JDO connect to any source (RELATIONAL and NORELATIONAL)
HIBENATE connect to only RELATIONAL DB
but HIRBERNATE has advantages in the relational schema
> recoding.
> Thanks.
> Darren Bell
Re: BIRT and ORM [message #139 is a reply to message #121] Wed, 17 November 2004 11:53 Go to previous messageGo to next message
Hi Darren,
In the initial release of BIRT, such ORM tools will be handled as custom
data sources.
BIRT will have extensions for custom data sources, at both report design
time and runtime. The spec on such extensions will be published when
details are available, and we will welcome your feedback then.
Linda Chan
Actuate Corporation
> recoding.
> Thanks.
> Darren Bell
Re: BIRT and ORM [message #142 is a reply to message #139] Wed, 17 November 2004 17:41 Go to previous messageGo to next message
Originally posted by: belldj.ntlworldX.com
Linda Chan wrote:
> Hi Darren,
> data sources.
> Linda Chan
> Actuate Corporation
>> without recoding.
>> Thanks.
>> Darren Bell
Thanks for the reply Linda.
I'll have a look at the spec when it comes out and provide some comments.
Re: Set a XML DataSource Programmatically [message #1846689] Fri, 08 October 2021 18:10 Go to previous messageGo to next message
Re: running recorded http script, no session [message #1846923] Fri, 08 October 2021 20:47 Go to previous message
Previous Topic:report middleware standard and something
Next Topic:Request for help passing an application parameter in Maximo BIRT
Current Time: Fri Nov 14 03:41:55 EST 2025
Powered by FUDForum. Page generated in 0.04333 seconds
