Home » Eclipse Projects » Eclipse Platform » local history
local history [message #114441] Fri, 22 August 2003 04:47 Go to next message
Originally posted by: mueller.software.email.de
Hi all,
my local history is completely empty although my project has about
50 files right now. The settings in the preferences are ok.
In which directory is the history stored?
Eclipse 2.1.1, Win XP
J
Re: local history [message #114655 is a reply to message #114441] Fri, 22 August 2003 10:20 Go to previous messageGo to next message
See Window > Preferences > Workbench > Local History
Default expiration is set to 7 days. All files older than 7 days probably
have been removed.
Chris
"jumu" <mueller.software@email.de> wrote in message
news:bi4l3e$log$1@eclipse.org...
> Hi all,
> Regards
> J
Re: local history [message #115812 is a reply to message #114655] Mon, 25 August 2003 04:23 Go to previous messageGo to next message
Hello Chris,
as I wrot: the settings are OK. But the history is completely emty.
The files are definitely not seve days old....
Any other ideas?
J
Re: local history [message #116406 is a reply to message #115812] Mon, 25 August 2003 14:38 Go to previous messageGo to next message
local history is stored under CVS.
If you edit a file, save it, and then do "compare with local history",
do you see the previous version?
Chris
news:bicgqc$6j9$1@eclipse.org...
> Hello Chris,
> Any other ideas?
> Regards
> J
Re: local history [message #117085 is a reply to message #116406] Wed, 27 August 2003 02:31 Go to previous message
OK, got it.
I've chosen the wrong menu item. "compare with local history" is what I
was looking for and it works fine.
Thank you very much....
jumu
"Chris Laffra" <Chris_Laffra@oti.com> schrieb im Newsbeitrag
news:bidl37$9q6$1@eclipse.org...
> Chris
> > Hello Chris,
> > Any other ideas?
> > Regards
> > J
Previous Topic:Ant plugin update to v1.5.4?
Next Topic:New Project Wizard
Current Time: Fri Jul 25 00:43:06 EDT 2025
Powered by FUDForum. Page generated in 0.28842 seconds
