plugin export fails [message #114410] |
Fri, 22 August 2003 04:11  |
good morning ( Germany ),
I wrote a simple plugin: it compiles and runs in eclipse. But now i want
to export this plugin. So I try the following: file --> export --> "Plugin
or Fragment" and select the plugin I wrote. After selecting a zip file and
pressing finish the following Message Pops up:
file:d:/<path>/<plugin name>/build.xml:50:srcdir attribute must be set!
Am I right in seeing this has something todo with ant? Maanwhile I cannot
export the plugin. Any help would the very usefull.
regards,
-thijs metsch
Re: plugin export fails [message #116096 is a reply to message #115549] |
Mon, 25 August 2003 11:18  |
Originally posted by: richkulp.NOSPAM.us.ibm.com
Actually, doing export plugin, under the covers, generates the
build.xml, runs it, then deletes it, as I understand it to be.
Rich
FUDForum. Page generated in 0.03892 seconds
