Use DataBinding APIs to update model when contents of Table change [message #114409] |
Thu, 04 December 2008 10:11  |
Originally posted by: spanprevention-nursubscriptions.gmail.com
The requirement is that when the contents of a table change (process
described below), DataBinding APIs should indicate that the model needs to
be updated.
I have a table that has 3 columns. The first column can be considered a
key and the other 2 columns are values (e.g. Column1 = 'ID', Column2 =
'DisplayName', Column3 = 'SomeValue'). When a row is selected, the idea is
to let the user change the values of columns 2 and 3 for that row. For
meet this end, when the row is selected, a couple of text boxes outside
the table are populated with the current values of columns 2 and 3 in the
selected row. The user can modify these values in the text box. When the
user clicks a button next to these text boxes, the values from the text
boxes are written to the respective columns of the selected row. This
works fine.
All of the above is in an editor that has some more widgets. There is a
Workbench SAVE action whose widget in the menu is to be enabled/disabled
using DataBinding APIs based on widgets in this editor.
The requirement is that when the contents of the table change (as a result
of actions described above), the DataBinding APIs should indicate that the
model needs to be updated by enabling the SAVE icon. I have been unable to
find a suitable SWTObservables API that i can use for this purpose. The
only API that i found applicable to the Table widget was the
SWTObservables.singleSelection() API, but this enables the SAVE icon when
a row is selected in the table, not when its contents change. This is not
what i want.
Any pointers/code snippets to resolve the above problem are much
appreciated.
TIA,
Best Regards,
- abhi
Re: Use DataBinding APIs to update model when contents of Table change [message #114444 is a reply to message #114409] |
Thu, 04 December 2008 11:21   |
Well databinding is not the appropriate place to decide if your model is
dirty though you could simply register to all value bindings and listen
for change events (skipping those coming from a master-detail action).
The much better solution would be to solve this at the model level
though as long as you use POJOs you need to write such a thing your own :-(
The Best Solution would be to use EMF + EMFEditDatabinding which
automatically gives you a CommandStack (=Undo/Redo-List) which you can
query / listen to to decide whether your model is dirty or not + you get
undo/redo for free!
If you want a tutorial on how to use these things in a custom
RCP-Application take a look at an example application I published
(yes I know you want that you write an RAP-Application but the concepts
are the same for a RAP-Application) at [1] (it's the datacentric
application talk). I know it sounds a lot of work but it will save you
from a tremendous amount of headaches.
Once the RAP people solved the SWTObservables#observedDelayed problem I
will publish my application as RAP-Example.
Tom
[1] http://tom-eclipse-dev.blogspot.com/2008/11/back-from-ese.ht ml
abhi schrieb:
> to be updated.
> is to let the user change the values of columns 2 and 3 for that row.
> For meet this end, when the row is selected, a couple of text boxes
> outside the table are populated with the current values of columns 2 and
> 3 in the selected row. The user can modify these values in the text box.
> When the user clicks a button next to these text boxes, the values from
> the text boxes are written to the respective columns of the selected
> row. This works fine.
> result of actions described above), the DataBinding APIs should indicate
> that the model needs to be updated by enabling the SAVE icon. I have
> been unable to find a suitable SWTObservables API that i can use for
> this purpose. The only API that i found applicable to the Table widget
> was the SWTObservables.singleSelection() API, but this enables the SAVE
> icon when a row is selected in the table, not when its contents change.
> This is not what i want.
> appreciated.
> TIA,
> Best Regards,
> - abhi
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Use DataBinding APIs to update model when contents of Table change [message #114479 is a reply to message #114444] |
Thu, 04 December 2008 16:00  |
Originally posted by: rherrmann.innoopract.com
regarding the SWTObservables#observedDelayed():
its use in RAP is often unnecessary as UI events like ModifyEvents
are already delayed or accumulated before delivered to the server.
Tom Schindl wrote:
> undo/redo for free!
> Tom
> abhi schrieb:
>> to be updated.
>> appreciated.
>> TIA,
>> Best Regards,
>> - abhi
FUDForum. Page generated in 0.04122 seconds
