Home » Eclipse Projects » Equinox » p2/pde testing p2 software update in rcp application using IDE (not running deployed build)
p2/pde testing p2 software update in rcp application using IDE (not running deployed build) [message #114322] Thu, 17 July 2008 10:16 Go to next message
I wish to use the p2 software update in my RCP application, and I would
like to test the "client" side of it in the IDE (I don't want to run the
headless build and run the application).
Is it possible to have the PDE mechanism create the necessary p2 profile
for this to happen.
Currently when I run the Help -> Software update, it gives me the dialog
that it cannot be run because
ProvisioningUtil.getProfile(IProfileRegistry.SELF) does not find the
profile (because it's not there).
Francis
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Re: p2/pde testing p2 software update in rcp application using IDE (not running deployed build) [message #114364 is a reply to message #114322] Thu, 17 July 2008 16:33 Go to previous messageGo to next message
This bug addresses this issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=224658
Apparently having a real profile created is not part of the 3.4
functionality.
> for this to happen.
> Francis
Re: p2/pde testing p2 software update in rcp application using IDE (not running deployed build) [message #114590 is a reply to message #114364] Fri, 18 July 2008 15:00 Go to previous messageGo to next message
In the CVS repo there is a plug-in called org.eclipse.equinox.p2.selfhosting
which was an attempt at doing what you are suggesting but it has not been
used in months (not sure it compiles). the idea is with that installed in
your dev environement a proper p2 profile would get generated on startup of
the launch configuration.
We are hoping to revive this in 3.5, but it is unclear if this will happen
with the workload we have.
"Francis Upton (News)" <francisu@ieee.org> wrote in message
news:g5oaag$fu5$1@build.eclipse.org...
> functionality.
>> for this to happen.
>> Thanks,
>> Francis
Re: p2/pde testing p2 software update in rcp application using IDE (not running deployed build) [message #114643 is a reply to message #114590] Fri, 18 July 2008 16:06 Go to previous message
Thanks, I would love to help, but I have my hands full with the CNF that
I have not yet devoted sufficient time to. But thanks for the pointer.
>> functionality.
>>> for this to happen.
>>> Thanks,
>>> Francis
Previous Topic:[p2] Director install accessing ganymede download site using local repository
Next Topic:Making p2 repos with PDE structured with categories and IUs
Current Time: Fri Oct 24 01:23:26 EDT 2025
Powered by FUDForum. Page generated in 0.04120 seconds
