Home » Language IDEs » ServerTools (WTP) » Javascript Editor not working with RC3?
Javascript Editor not working with RC3? [message #114223] Mon, 27 June 2005 14:39 Go to next message
After reading that M4 won't work with RC3, I downloaded the latest
integration build (I20050627), but it looks like the Javascript editor
still isn't working...I am not getting any syntax highlighting or
outlines. Is this a known issue?
Osman
Re: Javascript Editor not working with RC3? [message #114320 is a reply to message #114223] Tue, 28 June 2005 00:58 Go to previous messageGo to next message
It works fine when I try I200506280501 with its requirements. Did
you install everything properly?
- Nitin
Re: Javascript Editor not working with RC3? [message #114371 is a reply to message #114320] Tue, 28 June 2005 11:11 Go to previous messageGo to next message
Nitin Dahyabhai wrote:
> It works fine when I try I200506280501 with its requirements. Did you
I was under the impression that WST did not need all the added libraries
required by WTP. I will get those and try again.
Osman
Re: Javascript Editor not working with RC3? [message #114383 is a reply to message #114371] Tue, 28 June 2005 11:37 Go to previous message
> Osman
I installed all the prereq's and WTP, and it looks like it is working.
Thanks!
Osman
Previous Topic:Not Annotated Servlet
Next Topic:XML editor with non standard extensions?
Current Time: Thu Jul 24 02:27:37 EDT 2025
Powered by FUDForum. Page generated in 0.06068 seconds
