Home » Archived » BIRT » Java collection as a Table data source??
Java collection as a Table data source?? [message #114226] Tue, 24 January 2006 09:51 Go to next message
Hi!!
I'd like to use my Java object collection as a data source in a table.
Is it possible to do ??
I can send my collection to the report as a scriptableJavaObject but how
should I read it in my report ??
Regards, Wojtas
Re: Java collection as a Table data source?? [message #114262 is a reply to message #114226] Tue, 24 January 2006 10:20 Go to previous messageGo to next message
Originally posted by: abrunet1.gfi.fr
in your java code, you must pass your collection as a
scriptableJavaObject.
in your report, you create a datasource with a script.
then you create a dataset which use the new datasource.
then you link your table with the new dataset.
then open your dataset in code view :
in open method :
var iterate = myCollection.iterator();
in fetch method :
if (!iterate .hasNext()) return false;
var person = new
Packages.com.my.package.Person(iteration.next());
row["name"] = person.getName();
row["phone"] = person.getPhone();
return true;
(replace Person by your class in your Collection).
You must have in your class Person a constructor like this:
public Personn(String name, String phone) {
this.name = name ....
if you don't understand something, ask it.
Bye
Wojtas wrote:
> Hi!!
> Regards, Wojtas
Re: Java collection as a Table data source?? [message #115143 is a reply to message #114262] Wed, 25 January 2006 02:36 Go to previous messageGo to next message
Thank you for answer.
I'll try it today and let you know if it wors :-)
Re: Java collection as a Table data source?? [message #117365 is a reply to message #114262] Thu, 26 January 2006 07:01 Go to previous messageGo to next message
Originally posted by: xxx.xxx.com
thanks too, i try and that does work :
in my webapp :
task.addScriptableJavaObject("myCollectionObjectReport",myCollection);
my dataset :
in open method :
iterate = myCollectionObjectReport.iterator();
(and not with "var" like : var iterate =
why ? i don't know :D)
in fetch method :
if (!iterate.hasNext()) return false;
myObject = iterate.next();
row["myObject_code"] = myObject.getCode();
row["myObject_libelle"] = myObject.getLibelle();
return true;
(and not with "var" and "Packages.XX.XX" like : var myObject = new
Packages.com.my.package.MyObject (iteration.next());
and my table link with the new dataset.
Regards.
Denis.
Re: Java collection as a Table data source?? [message #117567 is a reply to message #117365] Thu, 26 January 2006 11:05 Go to previous messageGo to next message
I don't understand in my case it doesn't work without
For 'var' key word, i have already the probleme in some case.
Which version of birt do you use ?
Regards.
Arnaud
> in my webapp :
> my dataset :
> in open method :
> in fetch method :
> return true;
> Regards.
> Denis.
Re: Java collection as a Table data source?? [message #117591 is a reply to message #117567] Thu, 26 January 2006 11:23 Go to previous messageGo to next message
i use Report_Engine in my webapp, BIRT 2.0 RC1.
Denis.
Re: Java collection as a Table data source?? [message #117655 is a reply to message #117591] Thu, 26 January 2006 12:12 Go to previous messageGo to next message
I use birt 1.0.1 in a java application to generate PDF.
Re: Java collection as a Table data source?? [message #138091 is a reply to message #114226] Thu, 02 March 2006 09:36 Go to previous message
test
Previous Topic:Using rptdesign file outside a Reportproject
Next Topic:Can't Run Report w/ Parameters
Current Time: Sat Nov 08 07:29:35 EST 2025
Powered by FUDForum. Page generated in 0.04552 seconds
