Home » Eclipse Projects » Eclipse Platform » Running JUnit plug-in tests gives "Could not resolve classpath container: org.eclipse.pde.core.
Running JUnit plug-in tests gives "Could not resolve classpath container: org.eclipse.pde.core. [message #114185] Thu, 21 August 2003 16:16
[Sorry for the crosspost, but I'm not sure which is the
right newsgroup.]
When trying to run some home-grown JUnit plug-in tests
(that worked fine until now) for some of my refactorings
under 3.0-M2, I just now started getting the following
alert box immediately after selecting Run:
org.eclipse.pde.core.requiredPlugins"
and that's it; the run-time workbench never comes up.
The launch config, the project config, the JDK, and
eclipse settings are all the same as when things were
working. Everything builds fine, and I can run/debug
a runtime-workbench with my added refactorings (what
the JUnit plug-in tests are supposed to exercise).
The only recent change to this workspace is importing
some other unrelated JUnit test projects, such as
org.eclipse.jdt.core.tests.builder.
I can still run the eclipse-supplied JDT Refactoring
tests (org.eclipse.jdt.ui.tests.refactoring), and I've
compared my project's settings to the JDT Refactoring
tests project, as well as the corresponding launch
configs, but nothing interesting turned up...
Any ideas?
-- Bob
Robert M. Fuhrer, rfuhrer AT watson DOT ibm DOT com
IBM T.J. Watson Research Center
Previous Topic:Make update manager recognize site update?
Next Topic:resource tree is locked
Current Time: Sun Nov 02 01:44:44 EDT 2025
Powered by FUDForum. Page generated in 0.03504 seconds
