Home » Archived » BIRT » Reg : Upgrading BIRT 1_0_1 to latest version
Reg : Upgrading BIRT 1_0_1 to latest version [message #114166] Tue, 24 January 2006 08:52 Go to next message
Originally posted by: buday.metrikus.com
I've installed BIRT with the following components :
Eclipse 3.1.1
GEF Runtime 3.1
EMF runtime 2.1
birt_report_frame_work-1.0.1
With these components i'm facing some problems.
So pls suggest me the latest version of BIRT & their required components
Re: Upgrading BIRT 1_0_1 to latest version [message #114476 is a reply to message #114166] Tue, 24 January 2006 09:20 Go to previous messageGo to next message
Take a look at
http://www.eclipse.org/birt/index.php?page=build/install.htm l
BIRT 2.0 is out now and you should use it.
Make sure you get all the required files.
Jason Weathersby
BIRT PMC
"boni.uday" <buday@metrikus.com> wrote in message
news:8ae312866a656cafd929291a6f646ac3$1@www.eclipse.org...
> Eclipse 3.1.1
> GEF Runtime 3.1
> EMF runtime 2.1
Re: Upgrading BIRT 1_0_1 to latest version [message #118176 is a reply to message #114166] Thu, 26 January 2006 18:01 Go to previous messageGo to next message
I'd upgrade as Jason suggested. The configuration you listed is unsupported.
I suggest you keep Eclipse, GEF, and EMF and just delete BIRT.
To delete an installation of BIRT, do this:
1. Locate your Eclipse plugins directory, e.g. \eclipse\plugins.
2. Delete all directories that start with "org.eclipse.birt".
3. Locate your Eclipse features directory. If you installed on Windows in
the default location, this is "C:\program files\eclipse\features".
4. Delete all directories that start with "org.eclipse.birt".
5. Download and install BIRT Report Designer 2_0_0.
6. Restart Eclipse with the -clean option: eclipse -clean
Paul
> Eclipse 3.1.1
> GEF Runtime 3.1
> EMF runtime 2.1
Re: Upgrading BIRT 1_0_1 to latest version [message #118340 is a reply to message #118176] Fri, 27 January 2006 00:23 Go to previous messageGo to next message
WHich BIRT 2.0 component should i install?
Is it birt_report_framework_2_0_0.zip
Re: Upgrading BIRT 1_0_1 to latest version [message #118349 is a reply to message #118176] Fri, 27 January 2006 00:24 Go to previous messageGo to next message
or
birt_rcp_report_designer_2_0_0.zip
Pls suggest me
which componenet should i install
Re: Upgrading BIRT 1_0_1 to latest version [message #118482 is a reply to message #118176] Fri, 27 January 2006 05:00 Go to previous messageGo to next message
Hi Paul,
Thank you very much for ur kind response.
I've successfully installed BIRT 2.0.0
Once agin Thank you so much
Re: Upgrading BIRT 1_0_1 to latest version [message #118656 is a reply to message #118176] Fri, 27 January 2006 08:36 Go to previous message
Originally posted by: m.n.com
I have been installing BIRT in a different location - other than the
default plugin. This makes removing it much easier.
Paul Reeves wrote:
> Paul
>>Hi,
>>Eclipse 3.1.1
>>GEF Runtime 3.1
>>EMF runtime 2.1
Previous Topic:Bar rising high
Next Topic:I m unable to see the design
Current Time: Thu Nov 06 19:49:59 EST 2025
Powered by FUDForum. Page generated in 0.04227 seconds
