Home » Newcomers » Newcomers » Netbeans Keyboard Shortcuts in Eclipse
Netbeans Keyboard Shortcuts in Eclipse [message #114161] Wed, 02 November 2005 16:10 Go to next message
Originally posted by: a.b.com
Guys,
I'm new to Eclipse, but I've been a long time Netbeans user.
I really like the editor now that I'm really starting to get comfortable
with it, but there is one thing in the Netbeans editor that I really miss.
In netbeans they have some abbreviations that you can type that will expand
the word after hitting the spacebar. For example, if you type:
pu<spacebar> will expand to public
pr<spacebar> will expand to private
St<spacebar> will expand to String
As you can probably see this can save a lot of time and typos while typing.
Is there a way to do this in Eclipse?
Any help would be greatly appreciated.
Thanks in advance.
Re: Netbeans Keyboard Shortcuts in Eclipse [message #114187 is a reply to message #114161] Wed, 02 November 2005 18:10 Go to previous messageGo to next message
Two approaches:
Try using 'code assist' also known as 'content assist'
type a few characters of code > press CTRL + space or go to Eclipse > Edit
Content assist
A list of possible code completions appears.
Alternatively try 'auto activation' - this is a quicker way of getting what
you want as Eclipse takes a guess at what you want. You configure this by
going to 'window' > preferences > Java > Editor > Code assist
Cheers - Vince
"Schwame" <a@b.com> wrote in message news:dkb9ve$2ks$1@news.eclipse.org...
> Guys,
> expand the word after hitting the spacebar. For example, if you type:
> typing.
> Thanks in advance.
Re: Netbeans Keyboard Shortcuts in Eclipse [message #114487 is a reply to message #114187] Thu, 03 November 2005 11:48 Go to previous messageGo to next message
Thanks for responding.
I've been using the content assist with the CTRL + space, but it
takes a lot longer than typing a few characters of a word.
Another good example, is typing pst changes into printStackTrace();
As you can see this can save a lot of time while coding.
The auto-activation only seems to auto-activate the content assist.
Is there a way that I could make my own plugin to achieve this effect?
Thanks in advance.
j
"Vince Jacobs" <vincej@shaw.ca> wrote in message
news:dkbhac$bpc$1@news.eclipse.org...
> Two approaches:
> Content assist
> what you want as Eclipse takes a guess at what you want. You configure
> this by going to 'window' > preferences > Java > Editor > Code assist
> Cheers - Vince
>> Guys,
>> miss.
>> typing.
>> Thanks in advance.
Re: Netbeans Keyboard Shortcuts in Eclipse [message #114509 is a reply to message #114487] Thu, 03 November 2005 13:02 Go to previous messageGo to next message
Improving the response performance can be done by going into the preference
configuration and changing the number of milliseconds delay.
I Don't know about your own plug-in - sorry.
Vince
"Schwame" <a@b.com> wrote in message news:dkdf0u$oeb$1@news.eclipse.org...
> Thanks in advance.
> j
>> Two approaches:
>> Edit Content assist
>> Cheers - Vince
>>> Guys,
>>> miss.
>>> typing.
>>> Thanks in advance.
Re: Netbeans Keyboard Shortcuts in Eclipse [message #114661 is a reply to message #114487] Fri, 04 November 2005 05:34 Go to previous message
In recent builds (for example 3.2M3), define your template for
printStackTrace() and configure a separate command for template
completion (on the Java > Editor > Content Assist > Work in Progress
preference page). 'pst' will not be expanded automatically, but once you
press the template expansion button...
Hope this helps a little. tom.
Previous Topic:more help with java.util.scanner
Next Topic:Building jars.
Current Time: Wed Jul 23 03:58:35 EDT 2025
Powered by FUDForum. Page generated in 0.20552 seconds
