Home » Eclipse Projects » Equinox » Separating config.ini and osgi cache.
Separating config.ini and osgi cache. [message #114093] Tue, 15 July 2008 05:17 Go to next message
I am trying to deploy an equinox based application. I have a
requirement where in I want all the configuration information to be stored
in one particular filesystem location, while any data which changes at
runtime kept in a separate partition. Therefore I want config.ini in one
location, whereas the osgi cache in a separate location. I tried using a
couple of the runtime options, but none of them seem to work for me. I
also read about cascaded configuration, but could not understand how it is
used.
Simply put, my requirement is like this,
I have config.ini in C:\Tests\Configuration
In the command prompt, from C:\ , I run
java -jar org.eclipse.osgi_3.4.jar -configuration C:\Tests\Configuration
It generate the osgi cache and logs in C:\Tests\Configuration, but I want
it be on D:\Tests\Cache.
Can this be done? If so how..? Any help would be greatly appreciated.
Srijith.
Re: Separating config.ini and osgi cache. [message #114528 is a reply to message #114093] Fri, 18 July 2008 14:35 Go to previous message
The only way for this to be possible is if the config.ini is in a read only
folder. This will cause a "child" configuration area to be created that will
be locaed by default on the user.home (or something like that)
"Srijith" <ksrijith@novell.com> wrote in message
news:6c25e1d8e14273fce6ecd4fce4de105e$1@www.eclipse.org...
> used.
> Srijith.
Previous Topic:Programmatically setting an update site
Next Topic:IInstallFeatureOperation vs. P2
Current Time: Thu Nov 06 19:56:51 EST 2025
Powered by FUDForum. Page generated in 0.04711 seconds
