| AEP Engine doesn't deploy correctly [message #10405] |
Mon, 31 March 2008 10:29 |
Hi to all,
I've created a simple bpel file (very similar to the one that aep tutorial
makes you create) with the Eclipse Designer, and I'm trying to deploy it
with the AEPBpel engine as explained here
http://sse.cs.ucl.ac.uk/omii-bpel/docs/userguide.html#i_arch ive
Resuming, once created the server and added the bpel project (in my case
it's called myTut2.bpel), i right-clicked on ActiveBPEL 3.0 Server, then
"publish".
Now, i should see a bpr file on my project (as the guide says) but it's
not my case.
The last stuff I get in the console is:
Mar 31, 2008 3:40:21 PM
org.activebpel.rt.axis.bpel.web.AeProcessEngineServlet$AeTom catLogger
logInfo
INFO: [aeidentitysvc.bpr] Finished ActiveBPEL deployment.
logInfo
INFO: ********** ActiveBPEL In-Memory Configuration Started
that means that aeidentitysvc.bpr has been created.
Even searching on the entire harddisk for the last bpr files created, i
cannot see anything similar to myTut2.bpr...
Does anybody can help me?
What's wrong?
Thank you in advance
FUDForum. Page generated in 0.03383 seconds
