Re: Does server-side equinox support to be deployed in WebSphere6.1? [message #114071 is a reply to message #114064] |
Mon, 14 July 2008 10:17  |
> So does that means osgi entironment can hold another osgi environment as a
> bundle? That will be an extremely complex classloader mechanism!
It's probably not as complex as you think. The bundle class loaders are not
arranged hierarchically so that within a particular instance of the
framework things look fairly much the same regardless if you're in the nth
nested framework or a top-level instance.
> Are you sure:)? Positive :)
> And is there any limitation of the depth of osgi-nesting?
There's nothing in the framework that would prevent an arbitrary depth
however I don't this has been investigated much beyond about 5 nestings
though. On the other hand I've run 100s of top-level instances of the
framework in one process so don't see this necessarily being a problem.
-Simon
FUDForum. Page generated in 0.03820 seconds
