calling a servlet with tomcat plugin [message #114042] |
Wed, 05 November 2003 11:15  |
Originally posted by: eyal.bitansky.reuters.com
I am using eclipse 2.1.1 with tomcat 5.x and the latest plugin from sysdeo
(2.2 beta)
I have no problems to run and compile java files but when I try to run a
servlet I get into problems:
I create HelloWorldServlet in a tomcat project name Test
my url is : http://localhost:8080/Test/HelloWorldServlet
adding /servlet/ before the name of the servlet doesnt help as well
I have noticed that server.xml has a new line:
<Context path="/Test" reloadable="true"
docBase="C:\eclipse\workspace\Test"
workDir="C:\eclipse\workspace\Test\work" />
and I can see the servlet directory in tomcat's manager.
why can't I call the servlet?
was I suppose to write my own web.xml? or the plugin takes care of that?
by the way. the servlet code is:
import java.io.*;
import javax.servlet.http.*;
import javax.servlet.*;
public class HelloWorldServlet extends HttpServlet {
public void doGet (HttpServletRequest req,
HttpServletResponse res)
throws ServletException, IOException
PrintWriter out = res.getWriter();
out.println("Hello, world!");
out.close();
Thanks.
Eyal Bitansky
Re: calling a servlet with tomcat plugin [message #114612 is a reply to message #114042] |
Thu, 06 November 2003 21:12  |
just a thought, but make sure the invoker context in the /conf/web.xml file
isn't commented out. the default is to comment it out.
leon Webster
"Eyal Bitansky" <eyal.bitansky@reuters.com> wrote in message
news:bob7mo$f1n$1@eclipse.org...
> Hello,
> (2.2 beta)
> import java.io.*;
> out.close();
> Thanks.
> Eyal Bitansky
FUDForum. Page generated in 0.04137 seconds
