Home » Eclipse Projects » Equinox » [p2] Director install: artifact file for com.ibm.icu noot found
[p2] Director install: artifact file for com.ibm.icu noot found [message #113990] Fri, 11 July 2008 09:22 Go to next message
I am trying to us p2 director to install my RCP application. After
exporting the product with the metadata, I run p2 director (see below).
THe install runs fine for a while. It creates the features, plugins and p2
directories along with artifacts.xml. Then it ends complaining that
!ENTRY org.eclipse.equinox.p2.engine 4 4 2008-07-11 09:10:47.344
!MESSAGE An error occurred while installing the items
!SUBENTRY 1 org.eclipse.equinox.p2.touchpoint.eclipse 4 0 2008-07-11
09:10:47.344
!MESSAGE The artifact file for com.ibm.icu/osgi.bundle/3.8.1.v20080530 was
not found.
I can not figure out what is missing. The repository contains
plugins/com.ibm.icu_3.8.1.v20080530.jar. The artifacts.xml file in the
plugin includes
<artifact classifier='osgi.bundle' id='com.ibm.icu'
version='3.8.1.v20080530'>
<properties size='3'>
<property name='artifact.size' value='4467363'/>
<property name='download.size' value='4467363'/>
<property name='download.contentType' value='application/zip'/>
</properties>
</artifact>
Any ideas what I should be looking for?
The complete output from director follows.
Rich Scott
d:\rls\eclipse\3.4\platform\eclipse\eclipsec.exe
-application org.eclipse.equinox.p2.director.app.application
-nosplash --launcher.suppressErrors -consoleLog -flavor tooling
-installIU org.test.sample.product
-p2.os win32 -p2.ws win32 -p2.arch x86
-roaming
-profile Sample
-profileProperties org.eclipse.update.install.features=true
-metadataRepository file:D:/eclipse.build/repository
-artifactRepository file:D:/eclipse.build/repository
-destination c:/temp/ce2
-bundlepool c:/temp/ce2
-vmargs -Declipse.p2.data.area=c:/temp/ce2/p2
Installing org.test.sample.product 0.0.10.
Installation failed.
!SESSION 2008-07-11 09:10:20.516
eclipse.buildId=I20080617-2000
java.version=1.6.0_06
Framework arguments: -application
org.eclipse.equinox.p2.director.app.application -flavor tooling -installIU
org.test.sample.product -p2.os win32 -p2.ws win32 -p2.arch x86 -roaming
-profile Sample -profileProperties
org.eclipse.update.install.features=true -metadataRepository
-destination c:/temp/ce2 -bundlepool c:/temp/ce2
Command-line arguments: -os win32 -ws win32 -arch x86
-consoleLog -flavor tooling -installIU org.test.sample.product
-p2.os win32 -p2.ws win32 -p2.arch x86 -roaming -profile Sample
09:10:47.344
not found.
Re: [p2] Director install: artifact file for com.ibm.icu noot found [message #114505 is a reply to message #113990] Fri, 18 July 2008 14:28 Go to previous messageGo to next message
I'm not sure what could be going wrong here. Are you trying to install from
a local repository?
"Rich Scott" <rscott@cas.org> wrote in message
news:e80d4037f338e0e0b1dd2fffffffb6b9$1@www.eclipse.org...
> 09:10:47.344
> not found.
> plugin includes
> </properties>
> </artifact>
> Thanks
> Rich Scott
> d:\rls\eclipse\3.4\platform\eclipse\eclipsec.exe -application
> org.eclipse.equinox.p2.director.app.application -nosplash --launcher.suppressErrors
> -roaming -profile Sample -profileProperties
> file:D:/eclipse.build/repository -artifactRepository
> file:D:/eclipse.build/repository -destination
> emp/ce2 -vmargs -Declipse.p2.data.area=c:/temp/ce2/p2
> !SESSION 2008-07-11
> 09:10:20.516 -----------------------------------------------
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> x86 -roaming -profile Sample -profileProperties
> file:D:/eclipse.build/repository -destination c:/temp/ce2 -bundlepool
> c:/temp/ce2
> Command-line arguments: -os win32 -ws win32 -arch x86 -application
> org.eclipse.equinox.p2.director.app.application -consoleLog -flavor
> tooling -installIU org.test.sample.product -p2.os win32 -p2.ws
> -profileProperties
> c:/temp/ce2
> 09:10:47.344
> not found.
Re: [p2] Director install: artifact file for com.ibm.icu noot found [message #114579 is a reply to message #114505] Fri, 18 July 2008 14:55 Go to previous message
Pascal,
Yes, I am trying to install from a local repository (File: URL).
I don't know if this is related or not. Since writing this post, I ran
across an unexpected behavior in PDE Project Export. I posted this one in
eclipse.platform.rcp. It appears that there is some sort of caching going
on relative to the target directory of the export which impacts what gets
exported the next time. The first indication of some caching is that if I
delete both the export directory and the metadata repository (to rebuild
them from scratch), the repository can end up with multiple versions of my
plugins. If I change the directory name for the export, I only get the
current version. The other thing that I saw was that I was not getting a
copy of org.eclipse.equinox.launcher... in the repository. I changed the
feature configuration many ways and still could not get the plugin
exported, even though it would appear in the product export directory.
Finally I changed the name of the product export directory and then I
started getting the proper artifacts created.
I'm not sure if this was the problem relating to com.ibm.icu, but I have
since been able to create a good repository built, by changing the export
directory name periodically. So finally, I'm able to generate the
repository, use p2installer to install, run my applicaiton, and then
update it.
Rich
> a local repository?
>> 09:10:47.344
>> not found.
>> plugin includes
>> </properties>
>> </artifact>
>> Thanks
>> Rich Scott
>> d:rlseclipse3.4platformeclipseeclipsec.exe -application
>> !SESSION 2008-07-11
>> c:/temp/ce2
>> -profileProperties
>> c:/temp/ce2
>> 09:10:47.344
>> not found.
Previous Topic:IInstallFeatureOperation vs. P2
Next Topic:[p2] Director install accessing ganymede download site using local repository
Current Time: Mon Jul 21 21:24:48 EDT 2025
Powered by FUDForum. Page generated in 0.07369 seconds
