Home » Archived » Visual Editor (VE) » Some initial thoughts on the databinding framework
Some initial thoughts on the databinding framework [message #113901] Wed, 21 December 2005 14:59 Go to next message
Hi there,
I’ve been looking at the innards of the databinding framework today and had a few questions pertaining to the organization of the APIs. Not sure if this is the correct forum for these sorts of things - apologize beforehand if not...
Before I begin - Wow! It looks like a lot of work and thought went into the binding framework.
1- Was the Property object ever considered to own converters and validators? The Property object seems like _metadata_ for the actual domain-object values and a natural place for converters/validators. That way each bound control can use the converter/validators from the bound property; you can then avoid making the binding API more verbose than it needs to be. (Specifically, the creation of Table/TreeDescriptions here taking converters and validators as arguments when a bound Property could suffice.)
2- The converter object can be used to transform a data value to a UI component. This doesn’t seem quite right – shouldn’t converters be manipulating domain data and not be used to create UI controls? The only place I see it used is in Table/Tree bindings to create the custom label for the cells. Why not just let the developers set a LabelProvider directly on the viewers?
3- Why is the term 'Updatable' used to represent bound data models? I think this can be confusing. Not all bound data will be changed (updated). Why not name it IBoundData or IBoundValue or DataModel, etc? I’ve read the wiki documents, but I still don’t quite understand completely…can someone shed some light on the subject?
These are just questions, and in no way criticisms, of what’s been done:)
Looking forward to some discussion,
--Bill
Re: Some initial thoughts on the databinding framework [message #114164 is a reply to message #113901] Fri, 23 December 2005 11:27 Go to previous messageGo to next message
Thanks for your detailed feedback!
Bill Snyder wrote:
> Hi there,
No it's not. In the future, please put data binding threads on the
Eclipse.Platform or Eclipse.Platform.RCP newsgroups, and it really helps
if you put [DataBinding] at the beginning of the subject.
Thanks! In some senses, it's a third generation framework since the
people who designed and implemented it had done two complete data
binding frameworks before.
Hmmmm.... Validators-- a qualified yes. Converters, no.
Suppose you have two "things", A and B and you want to bind them
together so that changes to A are "updated" in B and vice versa.
In this situation, A and B form a graph. A and B are the nodes, and
data binding makes up the edge (or arc or line) between A and B.
But A and B may be of different data types, so they can't be bound
unless there is a pair of data type conversion functions between them to
convert A's type to B's type and vice versa.
We believe that the data type conversion functions live on the edge
between A and B, and not on either A or B themselves.
Similarly, either A or B might be a more relaxed data type than the
other. For example, supposing A is a String and B is an int, A is a
more relaxed data type than B. In this situation, before we attempt to
convert A's String value to an int for B, we have to validate that A's
value *can* be converted to an integer to begin with.
Since this validation is associated with the data type conversion
function, we believe that this validation function also lives on the
edge between A and B.
That is why the call to bind() accepts 3 parameters:
bind(A, B, bindSpec)
bindSpec is the stuff associated with the edge in the data binding graph.
But you raise a valid point about business rule validation being mixed
with the validation associated with data type conversion. We have a bug
for that: See bug #120582 where I argue that business rule validation
needs to be associated with the business object.
In this context, your suggestion of putting this optional validator in
the Property object is very interesting. Thanks!
I'm not sure I understand this suggestion...
Are you suggesting that TableDescription (for example), be changed to
something like:
td.addColumn(new Property(...))?
The person who wrote this part of the API is on vacation, and I can't
address it personally. I'll ask him to reply when he gets back.
Hmmmm... I guess we settled on this name because bound values are simply
values that are kept updated when an object that they depend on changes.
I guess if you really hate this name, you can file a bug and try to
rally support for some other name. We have until February to fight over
it on Bugzilla. ;-)
> done:)
Thank you for your thoughtful comments!
Dave Orme
Visual Editor Project lead
http://www.db4o.com -- The Open-source Java Object Database
http://xswt.sf.net -- XML-based SWT page description language
Re: Some initial thoughts on the databinding framework [message #114171 is a reply to message #114164] Fri, 23 December 2005 11:41 Go to previous message
> sorts of things -
> threads on the
> and it really helps
> subject.
Hey David - thanks for the reponse. Overall I *really* like the approach of the databinding API. I've used the SwingLabs databinding code extensively in the past and have actually rolled my own databinding framework SWT/JFace. (This was before I realized that your project was maturing).
Anyway, I'll continue this discussion on in the Platform newsgroups....
cya over there...
--Bill
Re: Some initial thoughts on the databinding framework [message #611696 is a reply to message #113901] Fri, 23 December 2005 11:27 Go to previous message
Bill Snyder wrote:
> Hi there,
something like:
it on Bugzilla. ;-)
> done:)
Dave Orme
Re: Some initial thoughts on the databinding framework [message #611697 is a reply to message #114164] Fri, 23 December 2005 11:41 Go to previous message
> sorts of things -
> threads on the
> and it really helps
> subject.
cya over there...
--Bill
Previous Topic:VE Tutorials???
Next Topic:Visually adding list members to a JComboBox
Current Time: Mon Jul 21 21:45:54 EDT 2025
Powered by FUDForum. Page generated in 0.36480 seconds
