Home » Eclipse Projects » Remote Application Platform (RAP) » CellEditors in M3
CellEditors in M3 [message #113844] Thu, 27 November 2008 08:49 Go to next message
I have a question to developers team.
I found a problem with CellEditors in M3.
If we have a TableViewer with cell editors inside and if there are a lot
of rows in TableViewer and the vertical scrollbar is visible and it is
scrolled down then the location of active CellEditor is incorrect. It
seems that the location is calculated without information about vertical
scroll position.
I can create a bug, but it is in M3 version. So, it is possible that this
bug is well-known. Should I create a bug?
And I also have to make a desision if it is possible to use CellEditors in
our application. It is possible if this bug will be fixed in M5. Is it
possible?
Thank you, Igor
Re: CellEditors in M3 [message #113950 is a reply to message #113844] Fri, 28 November 2008 03:05 Go to previous message
Originally posted by: rherrmann.innoopract.com
Igor,
this was a known issue and is fixed meanwhile. See here for more
information:
255963: [Table] TableItem#getBounds() returns wrong x and y
values if scrolling
https://bugs.eclipse.org/bugs/show_bug.cgi?id=255963
Rüdiger
> scroll position.
> this bug is well-known. Should I create a bug?
> in our application. It is possible if this bug will be fixed in M5. Is
> it possible?
> Thank you, Igor
Previous Topic:Deploying a RAP application
Next Topic:Slider
Current Time: Mon Jul 21 21:30:01 EDT 2025
Powered by FUDForum. Page generated in 0.04609 seconds
