Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] ClassCastException GenericMatchEngine
[EMF Compare] ClassCastException GenericMatchEngine [message #113718] Mon, 03 March 2008 09:04 Go to next message
When I run a code using EMF Compare out of Eclipse, I have:
org.eclipse.emf.compare.match.engine.GenericMatchEngine cannot be cast
to org.eclipse.emf.compare.match.api.IMatchEngine
It seems the problem comes from to the class:
org.eclipse.emf.compare.match.service.EngineDescriptor
at the line
engine = (IMatchEngine)element.createExecutableExtension("engineClass ")
Any idea?
Cyril.
Cyril Faucher
IRISA-INRIA - Rennes, France
[Breathe life into your metamodels www.kermeta.org]
Re: [EMF Compare] ClassCastException GenericMatchEngine [message #113744 is a reply to message #113718] Mon, 03 March 2008 11:07 Go to previous message
--------------040908070602040903020402
Cyril,
Strikes me as odd to say the least, as GenericMatchEngine implements
IMatchEngine. The only trigger of such exception I can think of is the
ClassLoader :(.
Could you give some more information as how you're using EMF Compare? is
it from a jar or an RCP application? Are you using it in an OSGI
environment?
The line of code you're pointing shouldn't be called outside of eclipse,
which is the reason I'm wondering what your use case is.
Laurent Goubet
Obeo
Cyril Faucher a
Re: [EMF Compare] ClassCastException GenericMatchEngine [message #615598 is a reply to message #113718] Mon, 03 March 2008 11:07 Go to previous message
Cyril,
ClassLoader :(.
environment?
Laurent Goubet
Obeo
Cyril Faucher a
Previous Topic:[EMF Compare] ClassCastException GenericMatchEngine
Next Topic:[TENEO] [JDO] library tutorial - connection getting closed
Current Time: Sat Jul 19 11:37:39 EDT 2025
Powered by FUDForum. Page generated in 0.65020 seconds
