JDk and JRE versions [message #113409] |
Mon, 23 January 2006 13:55  |
Originally posted by: to.sreddy.gmail.com
Hi Folks,
Does anybody knows about which versions of JDk and JRE does the BIRT.war
file supports?
I am getting an "unsupported version error"
Srini
Re: JDk and JRE versions [message #113723 is a reply to message #113647] |
Mon, 23 January 2006 20:58  |
Jason,
Thank you so much for ur reply,
Even if i go with web viewer example folder, do i need to download some
jars to my LIB?
I am using IBM Websphere, Where i have to copy the webViewer Example
folder ?
is ir WEBINF? or any other place?
If you have any documentation on how to integrate with other app servers
like JBOSS , IBM Websphere other than Tomcat, please send me.
Srini
Re: JDk and JRE versions [message #113748 is a reply to message #113723] |
Mon, 23 January 2006 19:14  |
Srini,
You should be able to take web viewer example directory
Copy itext-1.3.jar to /Web Viewer
Example/plugins/org.eclipse.birt.report.engine.pdf/lib.
Copy prototype.js to /Web Viewer Example/ajax/lib.
Copy Axis jars to the /Web Viewer Example/WEB-INF/lib
rename the Web Viewer Example directory to something like birtviewer and
then war up the directory structure and
publish it as a standard web app.
I put the description of doing this on JBOSS on Birtworld.
http://birtworld.blogspot.com/2006/01/deploying-birt-20-rc-t o-jboss.html
Hope this helps
Jason
"srini" <to.sreddy@gmail.com> wrote in message
news:699246e956ac0c57de612264f50b6521$1@www.eclipse.org...
> Jason,
> jars to my LIB?
> folder ?
> Thanks
> Srini
FUDForum. Page generated in 0.04090 seconds
