Home » Archived » Riena » Riena Widgets :: Code Snippets
Riena Widgets :: Code Snippets [message #10309] Thu, 04 September 2008 11:02 Go to next message
Hi,somebody can post some Code Snippets with Editable Cell in table widget?
thanks
Re: Riena Widgets :: Code Snippets [message #10437 is a reply to message #10309] Fri, 05 September 2008 09:56 Go to previous messageGo to next message
I saw, that: Riena's TableRidget this is not supported out of the box. And
Elias confirmed. There are plans to give this support, such as JFace ?
Re: Riena Widgets :: Code Snippets [message #10470 is a reply to message #10437] Fri, 05 September 2008 10:12 Go to previous messageGo to next message
> And Elias confirmed. There are plans to give this support, such as JFace ?
we are currently in the process of implementing ridgets for the widgets that we need most. I can currently not tell you
when editable cells are supported. You can still create a view and use SWT directly for that particular part of your
application without ridget support. I mean to can use of ridgets and widgets. That is a very good design I agree but it
will be quit a while until we have each and every widget covered.
Or you can create a contribution that adds this feature. :-)
Re: Riena Widgets :: Code Snippets [message #10501 is a reply to message #10470] Fri, 05 September 2008 10:43 Go to previous message
Yes, I wish to contribute, which procedure for myself qualify? :-)
Re: Riena Widgets :: Code Snippets [message #574414 is a reply to message #10309] Fri, 05 September 2008 09:56 Go to previous message
Re: Riena Widgets :: Code Snippets [message #574440 is a reply to message #10437] Fri, 05 September 2008 10:12 Go to previous message
Re: Riena Widgets :: Code Snippets [message #574468 is a reply to message #10470] Fri, 05 September 2008 10:43 Go to previous message
Previous Topic:Riena Widgets :: Code Snippets
Next Topic:Re: [Announce] UFacekit component proposal
Current Time: Fri Nov 07 04:13:54 EST 2025
Powered by FUDForum. Page generated in 0.03686 seconds
